I have 3 green lights clicking in the back of my tv and the tv wont come on can you please give me some assistence on what the problem might be
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
How long have you owned it?
When the bulb went out on mine it did something like that.( I have been through 3 bulbs now on my projector)
Or maybe you don't have the inputs in right. Try using the input/source button on the remote or unit to switch and that might get it tuned in to what inputs you have. BTW turn all your input sources... VCR, DVD, DTV, cable box...etc ON before you do that.
Another thought -- you mention 'clicking'... does it sound like clicking or perhaps a little more electrical like sparking. When sets go bad they have built "spark gaps" just like a spark plug and when they produce too much voltage it arcs across these in order to discharge the power without harming the set.
Otherwise I'd call where you bought it. Or a store that sells them.. Even decent repair shops will often give you good advice knowing you might become a customer anyway -- my central air recently went out and I called and made an appt and the guy gave me some ideas to check over... it was the fourth fuse (I only saw 2 at first) and it probably saved me 200+ on a service call.
Posted on Jul 17, 2010
My mitsubishi vs-6055 rear projection tv wont come on you can hear it click and tha green light comes on then it clicks again no pictuer at all . i did find yhe red wire that comes off the flyback was bad...
every rear projection tv has a projection bulb at the back yours is blown it will cost about $300-400 new zealand dollar to get a new one just buy a new tv preferably high definition lcd-plasma.
Aug 01, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Tv turn off and wont turn back on
Check the power supply board.
Please rate this a fixya
Jan 31, 2009 | Televison & Video
Green Light
Most power up issues on these LCDs are due to a dying power supplies.
I repair these power supplies for under $90.00, let me know if you need further assistance.
Oct 24, 2008 | Astar LTV-3201 32 in. LCD Television
Timer light flashing
The capacitors wont always show any outward signs of being bad. But it the LED blinks constantly without stopping thats telling you the DM isnt completeing the boot sequence. So most likely the capacitors are bad. But dont put the same ratings back. go with 1000ufs @25V but make certain they are the 105 degree celcius capacitors. If you need further assistance let me know
Jun 17, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Tv wont turn on
I had the same problem and took it apart. Before the repair there was no "click" when I pushed the button, a clue to the problem. The on-off button on the front pushes a weakly made angle piece of plastic inside which had broken. The plastic piece in turn is supposed to push an internal switch which is offset to one side.
I used epoxy (Araldite) to repair the broken plastic angle piece, but it still looks weak to me so I switch the tv off at the wall and leave the on-off button alone (though it does work now).
Opening the case requires some knowledge and care, and can be dangerous. It may void the warranty so be careful or give it to a qualified repair person.
Hope this helps!
Dec 12, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
