Question about Microsoft Office Professional 2007 Full Version for PC
Problem I have the same problem as you i had to re enter the key and it still wont run!! did you come right? and what did you do?
Ggggggfjfg
Posted on Apr 23, 2008
My dell powers up and starts to load but wont go any farther what do i need to do
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
once you have your computer running scroll to bottom toolbar right click select start task manager applcations you will see what running you might have a virus also in processes see what is ticking over
if you see something running that should not be select end now
or you might uninstall that specific program
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive have no input while chkdsk utility is in progress any input might further damage your computer
hope this helps
May 10, 2012 | Dell Computers & Internet
Hi my TV has a picture of a padlock and i cant unlock it tried to use remote it wont work it is a magnavox 29inch
hi,
For unlocking you tv you have to reset its v-chip. Do the following for the same.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
ok
Apr 11, 2011 | Philips Magnavox 20MT133S 20" TV
My computer is conected to the wireless router but my husbands new computer wont connect with the router - it keeps coming back with unsucessful. we have tried the pin code and the network key. please can...
Right click on wireless icon on the tray,, select repair.
Check and repair Winsock corruption.
Click Start. In the Start Search dialog box, type: cmd, and right-click cmd.
Click Run as administrator.
Type: netsh winsock reset, and then press the ENTER key.
Type: Exit and press ENTER.
Restart the computer.
Reset the TCP/IP protocol.
Type: netsh int ip reset, and then press ENTER.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | Gateway Belkin F5D7230-4 802.11g Wireless...
Ferrari 1100 cd drive wont read oor write
Please try this :
Open the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
[to open the registry, vista or 7, navigate to start, then type in regedit, choose from list, right click and say open as administrator. On XP, navigate to start, choose run, type in regedit and hit enter]
Then find the DVD & CD ROM key under above value.
Under the DVD & CD ROM key, find the values UpperFilter & LowerFilter and delete both seperately. Reboot machine and recheck. See below for picture
May 28, 2010 | Acer Ferrari 3200 Notebook
Product key wont work it runs on windows xp pro and was bought ready to use i have tried to put key in so many times it hurts
If you are entering in the correct key from the COA label on the laptop and will not activate, you are allowed 3 free calls from one unique phone # to microsoft regarding this. They will ask you for your key over phone and will provide you and instruct you how to enter an alternative string of characters to activate windows. Just make sure you haven't entered in the letter O in place of the number 0 cuz they both look similar.
Jan 23, 2010 | Acer Extensa 5620-4020 Notebook
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Phone wont ring on incomming calls?
Could be two things, first is DND or do not disturb. Make sure that its turned off by either pressing the DND button or feature #85.The second is that the ringing wasn't turned on in programming.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Mar 26, 2009 | NorStar M7310 Corded Phone
Trackball on blackberry wont ''enter anymore
use the actual
"enter" key located in the lower right hand corner of the keypad
Nov 11, 2008 | Cell Phones
Microsoft Office Professional 2007 Full Version for PC Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
