Onn freeview box - no ch12, and multicopies of 2 progs recorded
Onn freeview box - 1. Doesn't appear to have channel 12(yesterday).
2.It appeared to have 20 copies of 2 programmes recorded. Had to manually remove them. Idiot guide to solution appreciated.
  • 177 Answers
It sounds like you might have a signal related problem. If you are missing channel 12, it is likely that some other channels from that same group are missing too. Run a fresh auto-setup, and see what comes in. If you can find a menu that lets you test the signal strengths, then make a note of how strong they are. If you find that you are suffering low signal strengths, you will probably find that getting this sorted will rectify the recording problem too.
Posted on Jul 17, 2010
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
Hi my mum has been given a dvd/video combi Technika DVR100 as her one does not record her progs while she is at work after the digital changeover.. question is will this record her progs which she watches...
You would have to connect the free view box to the vcr with a scart lead.Plug it into av2 on the vcr.To record select av2 on the vcr then set the channel on the freeview box.
Oct 16, 2010 | Televison & Video
I cannot get any tv channels though my panasonic
This model only has an analogue tuner so wont receive anything if the analogue signal in your area has been switched off. either buy a new new with a freeview tuner built in or just use that one in conjunction with a freeview box.
Dec 02, 2009 | Panasonic DMR-ES10 DVD Recorder
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Oct 01, 2009 | Uniden BC350 Base Scanner
Lost BBC channels on my SAGEM PVR6200T during a retune
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jul 06, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Dvd recorder hard drive DVDR5350H
This depends on how your video signals are delivered to the box, in most cases terrestrial TV signals received by ariel, cable are passed through the recorder, then to your TV, this means you can record 1 channel on the box and view another, it appears that this recorder only has 1 tuner so you cannot record 1 station and watch another on the output of this box.
with regard to freeview / satellite tuning, these are connected directly to the DVR and they only have 1 channel to view at a time, so unless you acquire a satellite / cable tuner which allows for dual channels or if you acquire a second cable/sattelite box from your provider it is not possible to record 1 channel and view annother
so this problem can be circumvented with other products, but the expense may be more than you expected, as most cable / sattelite provders will charge to provide a second box. also you will also have to be aware of interfeerance with remotes if 2 sat boxes are used. as the remotes are likly to be similar.
Oct 03, 2008 | Televison & Video
Dmr-es10 dvd recorder - cant get the machine to record digital channels form tv
Channels 1-5 are I believe for Analogue reception. To record from my digital Freeview box, I'm plugged into SCART port 2 (bottom most port on right hand side of machine as you look at it from the front). Use your remote to change the channel to A2 with the <CH> rocker button just above the video+ button on the controller. This will then record whatever channel your freeview box is set to - the only pain is you can't watch a separate channel whilste recording.
Kind Regards
Brad
Apr 01, 2008 | Panasonic DMR-ES10 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
