How do i disconnect my old washing machine - Washing Machines
  • 101 Answers
First you disconnect the power cord the shut off the hot and cold water valves, remove the two inlet holes .
Posted on Apr 21, 2008
How to remove washing machine from jayco sterling 2013
I PRESUME YOU WAN'T TO REMOVE A OLD WASHING MACHINE,
1. PULL OUT ELECTRICAL SUPPLY PLUG.
2.PULL MACHINE OUT A BIT TO GAIN ACCESS TO BEHIND MACHINE, SOME MACHINES HAVE COLD WATER SUPPLY PIPE ONLY BUT MOST HAVE HOT AND COLD SUPPLY PIPES.
THERE SHOULD BE A SHUT OFF SUPPLY VALVE AT THE SUPPLY SIDE OF THE TWO HOSES, CLOSE THEM BOTH THEN DISCONNECT HOSES, DRAIN HOSE SHOULD JUST LIFT OUT OF PIPE BEHIND MACHINE , NOTE ALL HOSES WILL LEAK SOME WATER ONTO FLOOR IF LAYED DOWN
A SACK TRUCK IS THE BEST WAY TO MOVE MACHINE
Nov 12, 2016 | Washing Machines
How do I fix my washing machine? It doesn't appear to feed enough water into the machine. The machine runs through a full cycle but appears low on water even in the middle of a full wash cycle.
I can try to explain the difference between today and the old washing machine. My question would be, are you satisfied with the washing result? If so, then everything is fine.
There are four factors that affect the washing and they make one single round (duration, temperature, mechanical action, chemical action). Old washing machines are spending more water, more detergents, more electricity power, and consequently more spoiled environment and duration of washing was app. from 1 to 1.5 hours. Today washers use less water, less detergent, less energy power, less polluting but because longer duration of washing cycle app. from 2 to 3 hours, wash result was the same as in the old machine.
I think that today confuses people how is possible that washing machine wash three hours (longer than before) and consumes less energy? Believe me this is true, and every service tehnician will explain it.
Because old habits many customers put the same amount of detergent (do not read the manufacturer's instructions) and therefore have problems with the skin. That is why an increasing number of washing machine has the option of additional rinsing cycles.
Dado
Jul 23, 2015 | Bosch Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Disconnect hot water pipe on washing machine
you need to shut the hot water off some were if you need to at the
hot water heater it's self
Apr 05, 2014 | Washing Machines
My washer won't spin and the belt is fine. What do I do?
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
For that reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Other than lose or worn belt there are various reasons that cause washing machine not to spin.
Check the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in its place.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
So there are various conditions when a washing machine wont spin. Please check this link to get a detailed idea related to your problem:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | GE WBSR3140DW Top Load Washer
It does not spin - error
Hi
Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
May 03, 2011 | LG Washing Machines
Water runnning out from bottom of washing machine
Barbarahaps,
I had a similiar problem with a Brand X washer. the problem may be your water pump. if so, it is an easy fix for someone who is mechanically inclined. you first must see where the water is leaking from. when i did this, i securly placed my washer on cinder blocks so that i could see underneath it, and let it fill with a little bit of water, then i could clearly see the water leaking out of the water pump. the key concern here is safety, make sure that the machine fills with only a little bit of water, and then cut the power off to the machine to ensure it doesn't start going through its cycle while up on the blocks, creating a potential hazard. If it is the waterpump, find a washer repair store, tell them the year and model machine you have, and get a water pump on order. the water pump is a pretty straight foward repair--you disconnect power from the machine, turn off and disconnect the water supply, disconnect the drain pipe, and tip over the washer to expose its under side. you disconnect the hoses going to the water pump, remove the attaching bolts, and install the new pump. then you hook everything back up and you should be good to go. hope this helps.
Nov 28, 2008 | Speed Queen AWS52NW Top Load Washer
Washing machine problem
it could be that the carbon brushes need changing on the motor. you can drain the machine if there is water in it by disconnecting the outflow pipe from the u-bend under the sink and lowering it into a bucket. This will empty any water in the machine (most of it any way), at the same time you can check for blockages in the outflow pipe while it is disconnected. If the machine is at least five years old then the carbon brushes are easy enough to change yourself, they are seated each side of the motor which will be on top of the machine. Simply carfully disconnect the electric cables on each carbon brush, gently slide them out and replace them by carefully sliding the new ones back into place and then connecting the electric cables again. The carbon brushes for hotpoints were universal for the older models 5 years old or more, but the newer version have cleverly put the motors on the bottom and are hard if not impossible to get to. You will then need to call out an engineer. Always make sure that you disconnet from the mains before touching anything within the machine, and if you are not confident in what you are doing the don't do it, call an engineer.
Oct 23, 2008 | Hotpoint WMA46 Front Load Washer
Admiral AL46000 2 speed washing machine
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Sep 13, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
