Question about Nelson Sprinkler: Traveling Tractor
I used the sprinkler last night and it worked beautifully. I moved the hose to another location this afternoon and the rear wheels seem to be frozen they will not turn.
    Problem Solver:
  • 5 Answers
Change speed and then spin the boom
Posted on Jul 28, 2010
Orbit traveling sprinkler won't move wheels turn when in neutral but not on high or low setting worked fine last night now nothing!!
I have a brand new orbit traveling sprinkler and the wheels won't move - they're frozen. The directions say to "Pull out the stopper underneath the sprinkler between the back wheels ..." and there is a white knob attached to a spring. When I try adjusting that, the wheels stay locked, frozen, won't move. What am I doing wrong?
Aug 11, 2014 | Garden
Bernina frozen, nothing moves
it's possible that something has broken or come loose inside the machine and the machine needs to be checked..
Jun 26, 2013 | Sewing Machines
Right rear tire frozen
Handbrake mechanism, brake caliper or brake piston could be partially siezed or possibly rear wheel bearing siezed. If hanbrake was on over night start with that and then work on from there.
Dec 28, 2012 | 1998 Buick LeSabre
My traveling sprinkler won't move. The wheels rotate but it seems the gears don't engage. What should I try?
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Apr 29, 2011 | Nelson Sprinkler: Traveling Tractor
The igition seems to be frozen. The battery is good as all the lights, buzzers etc are working. You put the key in the ignition and it won't turn. I've tried moving the steering wheel, made sure the...
It's possible. The parts store sells a small aerosol of deicer made for key holes. I would try this sparingly as there are electrical pieces in there. Good luck
Randy
Jan 21, 2011 | 2004 Suzuki Verona
My gps is frozen since ysdtay night.I t shows no movement n its frozen stating univeristy bld.What do I do??I just got it last month & did not buy the protection plan for it..What is the problem
mine was frozen 2. i called support and they helped. first hold the button 2 turn it off for 10 sec. reboot if u had trip ie. address programed in cancel it. That worked. Also not sure if this had anything to do w/ it but my battery was low and the gps powered off. I then plugged it in to the car charger this may have rebooted my gps. It now works fine.
Jan 17, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Rear brake sticking
Your saying as you drive it locks and skids? You say as you try to pull out the wheel is shuck and it won't turn? Or your saying that you detect that the wheel is dragging and the wheel turns fine? Is the other rear wheel sticking? The parking brake pedal is it all the way up? With the pedal up are the parking braek cables under the truck going to rear wheels tight or taugt but moving or slack and hanging. As this cable enters the hosing going to the rear wheel about an inch from the housing ( cable Housing ) clamp on a pair of vise grips or other locking pliers and hit them with a hammer towards the rear wheel. As your trying to make the cable go back as much as it's going to. Check both sides as it's possible that thier frozen in the cold weather. It's wise to avoid using the parking break in cold weather as they get mositure in them over time and with them frozen on the brake wil stick. If you find the cables slack with the pedal released and beating them back towards the wheel does'nt seem to be releasing the break you may need to heat the cable with a tourch to free them. The other answer is the rear break came aprt someway and the break shoes are bound up against the drum. The wheel bearing is possible too unless you can tell is the break.
Dec 12, 2010 | 1990 Chevrolet K1500
Front brakes dont seem to be working properley. new pads fitted.vacum pump pulling min 14 ins on tickover,20 ins at 1500 revs.vacum hoses replaced,but rear wheels lock and the front end doesnt seem to be...
When was the last time the brake fluid was flushed? Spongy/unresponsive brakes can sometimes be due to moisture/air in the brake lines. You can take the wheel off and get someone to push the brake peddle and see if the brake caliper is moving at all. If it is moving, but not enough to stop the wheel, I'd recommend flushing the brake fluid. If the caliper is not moving at all, it could be the caliper itself (but its very unlikely that both would go bad at the same time)
Nov 11, 2009 | 1994 Isuzu Trooper
Nelson Sprinkler:  Traveling Tractor Logo
282 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
