Question about BenQ PDP-46W1 46 in. HD-Ready Plasma Television
I have a 46'' Benq LCD tv. It got turned off when my wife bumped the extention plug. Now when i try to turn it on, the red light blinks followed by the green indicator (ON) but there is no picture as the screen remains off. THis is the WOW SRS SYSTEM. What can i do?
    Problem Solver:
  • 10 Answers
Try ti unplug it overnight to reset th eeprom chip inside the tv
if dont work something is short in the power supply
Posted on Oct 28, 2013
Benimur
  • 6966 Answers
SOURCE: benq lcd tv
Hi zippie, Based on your post/description, I am inclined to suspect the backlight which is actually a CCF a small fluorescent tube about 2mm diameter the width of your display either at the very top or bottom of the screen. At times it can also be the inverter circuitry that powers up the said tube. One way is to run your PC and display as if nothing is wrong giving it a minute or soto finished booting everything. If looking closely you will notice semblance of your desktop albeit very faint, very dark or using a flashlight provide illumination to the display at an angle and the display is there, then chances are it is the backlight. Otherwise, it can be the input circuitry. Of course you have to open the monitor up and replace the defective component, More often than not no soldering required. Hope this gives you an idea or two. Lots of luck and pls post again how things turn up. If
Posted on Aug 09, 2007
  • 17 Answers
SOURCE: Benq Plasma TV
Panel is bad; you need to replace it. Go to the nearest repair center.
Posted on Mar 04, 2008
SOURCE: BENQ LCD TV Screen
your bes off just geting a new unit.. i have two of these but the invter died in both. so ifyou still have your on hand laying around somewhere and you know the invter works hit me up..
Posted on Sep 04, 2008
SOURCE: Need to Buy a main system board/controler board for BenQ DV3750
Really Did not find a solution because we already know the problem. i.e the mani/digital board. BenQ will not sell us the part. We are still looking for a supplier.
NEVER NEVER Buy BenQ
Posted on Nov 18, 2008
  • 8 Answers
SOURCE: internal cracked screen on benq dv3750
you cant falls under cusatomer abuse so you gotta pay for a new panel or buy a new one... btw, panels cost more than what yopu originally paid for the uin it
Posted on Jul 19, 2009
I have a Curtis LCD TV. The red standby light turns on when I plug it in, but will not turn on (either by remote or the physical button on the TV). What could be the problem?
There could be a list of different problems. Usually, the red lamp will blink in a particular sequence, which tells the tech which board is most likely the problem. This is not a 100% accurate, because another board that has an issue, could cause the first board to interpreted incorrectly by the microprocessor IC(computer within your TV)
Dec 07, 2014 | Curtis Lcd4686a 46" 1080p 120hz Full Hd...
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Nov 16, 2009 | Polaroid Televison & Video
TV will not come on, red power light clicking off and on.
This problem is caused by a couple of faulty electrolytic capacitors located on the power supply pcb. Think they are both 1000mfd 35v
Aug 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Will not turn on just clicks and red light off and on
The cycle clicking comes by following reasons:
Power supply defective.
Mainboard defective.
Other boards defective. TV needs to check to isolate correct problem.
As far as I see, the 46" LCD has common problem of the power supply.
Aug 13, 2009 | Televison & Video
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Jul 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
BenQ PDP-46W1 46 in. HD-Ready Plasma Television Logo
71 people viewed this question
Top BenQ Televison & Video Experts
Marvin
Marvin
Lawrence Oravetz
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
