Question about Microsoft Windows Vista Ultimate Edition
Requesting answer 1) Blue ray disc optical drive has got howmany lenses. 2) Is it necessary to format the secondary HDD to create a new RAID configuration
  • nhuellemont Aug 24, 2008
    i upgrade my windows vista premium with vista ultimate and blueray disk dont play shows incompatibility, how i can fix the problem?
    Genius:
  • 2,785 Answers
Negative miniscus doublet lens,Objective (disk read) lens,negative cylindrical lens,Negative elliptical lens.
yes
Posted on Apr 21, 2008
Need to increase the hdd size in a dell poweredge 1600sc with raid 1
You will not be able to increase the hdd size of a raid array, it's size is set. If you need more storage, you can add additional drives ( either in raid or standalone ) and use the new drive(s) for storage, but the original array will remain unchanged. The other option is to back up all of your data, install new drives and create a new array.
Feb 10, 2011 | Dell PowerEdge 1600SC Server
I was assembled a PC to edited video HD. This PC comprises: mothercard Supermicro X8DAH+, 24 GB of RAM, 2 X Xeon 5620, 1 X SSD OCZ Agility 2 3 X HDD Hitachi 1TB CD/DVD/BR LITEON ihbs112 GPU...
Remove the 3 hard drives and install Windows on the SSD. After successfully installing Windows you can add the hard drives and create your raid array later. Or even better, pick up a cheap RAID card so your CPU doesn't have to do all of the RAID controller work.
Dec 15, 2010 | SuperMicro X8DAH+F motherboard Intel 5520...
I upgraded matheboard from p6t6 (stopped working for some reazon) to p6t7. My hard drives have been set up to raid. I have windows 7 ultimate installed. I set bios to raid and choose proper disc as boot 1...
On many systems with RAID1 support built into the mobo chipset, that system includes some RAID management software in BIOS. You won't see it until you turn on RAID capabilities in the BIOS and add a drive. But you might find all the details you need in manuals on the matter from Dell, so look for those. They could have come with your machine, or you may have to search their website and download.
On systems I've seen you create and manage RAID arrays using that built-in software, NOT Windows tools. In fact, some RAID1 management tools would allow you to convert a single stand-along HDD to a RAID1 array by adding a matching HDD unit and then having the system copy all the data to the second drive. This is almost the same as the process to repair a damaged RAID1 array by replacing one faulty drive with a new one and rebuilding the array.
HOWEVER, Windows ALWAYS needs a RAID driver installed in it to use any RAID array. If you are simply booting from a "normal" stand-alone disk into Windows and then using a RAID array as a data storage system, the RAID driver installation can be done any time after Windows is running as you set up the new storage system. BUT Windows in ANY version cannot BOOT from a RAID array unless the RAID driver has been installed at the very beginning of the OS installation. This implies that, if you want to convert your single disk into a RAID1 2-disk array and use ONLY that as the HDD resource in the machine, you will need to re-install Windows, this time including the required RAID driver install at the beginning, in order to boot from that array.
I have read that there may be ways to convert a non-bootable RAID array into bootable by some complicated editing of Windows registry and boot files in order to force it to load the right driver at the right time from the right spot on a HDD, etc. But I am not SURE that would work. It's definitely for the adventurous knowledgeable techie.
So here's a quick guide to installing hardware RAID on a motherboard that features a RAID controller. These steps assume you are performing a clean Windows 7 install rather than an upgrade, and they might differ depending on your system set-up, but the general principles should be the same.
  1. Download the RAID drivers for your motherboard from the manufacturer's website and save them to a memory stick.
  2. Back up all your important data!
  3. Turn your PC off and unplug it.
  4. Install 2 hard disks preferably with identically capacity into your PC.
  5. Turn on your PC, press the delete key or F2 key when prompted to get to the BIOS menu.
  6. Find the option to select the RAID mode, save your settings and exit BIOS.image.axd?picture=bios-raid-options.jpg
  7. On reboot you should see a new menu option to enter the RAID controller settings. Enter the key combination when prompted to get to the RAID controller menu. image.axd?picture=amd-raid-menu.jpg
  8. Create a new RAID array selecting either RAID 0, or RAID 1.
  9. Select the disks that will form the array, save the settings and exit.
  10. On reboot press the delete key or F2 key when prompted to get to the BIOS menu.
  11. Check the boot sequence of your PC and ensure your optical drive is top of the list.image.axd?picture=bios-boot-sequence-options.jpg
  12. Insert your Windows 7 disk into the optical drive and exit the BIOS.
  13. On reboot press any key when prompted to boot from the optical drive.
  14. Windows 7 should start installing.
  15. Select your localisation settings and click next.image.axd?picture=localisation.jpg
  16. Click "repair your computer" and click the "load drivers" button.image.axd?picture=windows%207%20repair%20menu.png image.axd?picture=load-drivers-option.jpg
  17. Insert your memory stick and browse to the correct driver and install.
  18. Exit back to the Windows 7 install menu click "Install now" and on the next screen click "Custom (advanced)" to perform a clean install.image.axd?picture=install-windows-custom_thumb.jpg
  19. When you are asked where you want to install Windows 7 you should see that the 2 RAID hard disks are now visible as just 1 drive.
  20. Add a partition to the new drive so Windows with be able to recognise it.
  21. Continue installing Windows as normal.
Dec 04, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
V have server 2003, in that v add a seperate hard disk for mirroring purpose. how to configure a mirror or raid?
1) to mirroring as a RAID, you require an additional HDD
2) right click on my computer, and select manage.
3) expand the "STORAGE" tree & go to disk management.
4) you have to convert your primary and additional both HDD into "DYNAMIC DISCS" by selcting your HDD and right click, and select convert into dynamic disks.
5) now create MIRRORED VOLUME after reboot.
Aug 14, 2010 | Computers & Internet
Confuguring raid5
Hi
You would need 4 Hard disk drives in total. you would need to create 2 RAID 0 (striping) and then Mirror them (RAID 1). to elaborate, HDD A&B will be at RAID 0 as well as HDD C&D. after, you would have to Mirror your two RAID 0. (raid 0+1 is also known as raid 5)
Hope this helps.
Jul 09, 2010 | IBM x3400 Server
I WANT TO INSTALL LOCAL DISK D ON MY COMPUTOR?
i lose my local disc d in my komputer,my dvd rom can read a disc.how can i instal
Sep 16, 2009 | Dell Dimension 4600 PC Desktop
RAID rebuild problem
Your NUMBER 1 ENEMY when doing multiple drives in a single case is HEAT!!!! Make 100% sure those drives are COOL!!! if not you will continue to have issues.
Dec 10, 2008 | Biostar P4M800-M7A Motherboard
Problem with creating array
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Aug 31, 2008 | Dell PowerEdge 2600 Server
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Hard drive..
Using SATA, there is no Primary/Secondary Master/Slave connection. Each HDD is connected to One port straight. As for partitioning, you can either use Fdisk or you can boot straight from the Windows CD and create Partitions and load Windows.
Sep 11, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
