Question about Toshiba Satellite A60 Notebook
I just brought a new laptop ( toshiba, satellite) turned it on for the first time set few settings quickly then closed the lid for a few moments when i opened it up again it was off so i turned it back on and it came up with the following - - BOOTMGR MISSING - press ctrl - alt - del to restart.
  • 10,319 Answers
Upon turning it on keep pressing the F8 key to obtain the repair screen
Choose start windows in the safe mode with the COMMAND PROMPT
When the screen shows C:/ type in chkdsk /f /r
Then restart the computer
If the windows still won't start take the unit back for exchange or have the BOOTMGR installed
Posted on Jul 17, 2010
Im running a external MONITOR. How can keep windows running when I shut the lid to my laptop? thanks
Windows XP:
By default, all laptops either go on standby or turn off to save precious battery, but you can override these rules from the Power Options (XP) in your control panel (Start > Control Panel > Performance and Maintenance > Power Options) and click on Advanced Tab and override the settings according to your preference.
I prefer "Do nothing" while closing the lid. Although this is real simple, few of us might not know it. I
Windows Vista/7:
How to Stop Laptop/Notebook Goes To Sleep or Hibernation when Closing Lid in Windows Vista
  1. Log on to your computer as an administrator. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the "Power Options" dialog box's "Advanced Settings" tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for "Lid close action" by selecting a new option from drop down menu for both On battery and Plugged in. do-nothing-lid-close-281x300.jpg Based on own preference, it's possible to set other action from the menu too. Available for selection is Do nothing, Sleep, Hibernate and Shutdown.
  7. Click OK button.
Jun 18, 2011 | Toshiba Satellite A135-S4527 Notebook
Satellite L305-S5875 backight on/off switch in the hinge keeps shutting monitor off.
If you can't replace the switch, go to your power settings and set the option for action to take when the lid is closed to none.
Feb 28, 2011 | Toshiba Satellite L305-S5875 Notebook
Toshiba satellite p205-s6267 backlight
Your system is consuming much power.
Go to Control Panel, Power Options.
Click "Advanced Power Settings" for your current power plan.
Under the section "What happens when I close the lid", choose "Do nothing" for both "Battery" and "Plugged-in".
Click "Apply" and "Ok".
Now, close the lid of your laptop and open it, it would restore but next time don't overload your system power.
This is common with Dell and Toshiba.
Apr 03, 2010 | Toshiba Satellite P205-S7402 Notebook
The computer hiberates when I close the lid, then I have to shutdown & restart to resume working. Can I avoid this somehow?
  1. right click your desktop and select properties
  2. select the screen saver tab
  3. at the bottom click the "power" option
  4. deselect the option for hibernation
  5. make sure your hdd is NOT set to turn off when the lid is closed
you can actually set the laptop up to continue running even programs when the lid is closed. this is the best option if you are constantly running application that require an extended wait period between startup and shut-down
good luck and pls rate this post
Mar 23, 2010 | Toshiba Satellite Pro L300 Notebook
Running Windows 7. When I close my lid, for
have you tryed reseting the battery settings in the control panel. you can change what the power button does and what you want the computer to do when you close the lid.
Mar 07, 2010 | Toshiba Satellite P300D-ST3711 Notebook
Put my toshiba laptop into sleep mode closed the lid, reopened it within seconds, and now the laptop will not come back on
Reboot the laptop, go to control panel > power options > go through the settings, especially what does the computer do when lid is closed and change the setting to "do nothing", turn off hibernation if it is on. Change other settings to now allow the computer to go to sleep, just let it run until you decide to turn it all the way off. Sleep mode and Hibernation cause more problems than do good.
Sep 17, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
Toshiba satellite a215-s7422 laptop wil not turn on
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
Jan 31, 2009 | Toshiba Satellite A215-S7422 Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Problems with Toshiba Satellite A135
It sounds like you need to adjust your setting when you close the lid. If you set it to do nothing when the lid closes that should sort out your problem. Often it won't let you adjust them so if you uninstall the power management and then do the adjustments in the power settings then you should be ok
Dec 25, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite A60 Notebook Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
