Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
SPLIT AC NOT COOLING AFTER 30 MINUTES
I have NIKAI 1.5 TON AC. It does not run continuesly. For example, if switch it on, it will run for 30-45 minutes and will provide cool air. After that it will not provide "cool air", only fan will run.. When i am checking the "out-door" unit, which is on the roof, it is off. Out door is not running at all.. But, inside my room, its switched on. It will blow dry air now.. Then i m switching it on and off again and again, so that it runs, but with no success. I will switch off it for 30-40 minutes. After 35 minutes, when I am switching it ON, it will provide COOL Air. ........ for 30-45 minutes....... after that, it will not blow cool air again...
Last week, i called on one AC mechanic, he repalaced the "CAPACITOR" inside the outdoor unit. He told me that this is because of capacitor problem.. But nothing has changed since... and mechanic has no answer.. Plz let me know the answer/reason and any suggestion/recommendations.
  • 70 Answers
Sounds like the out door fan is not running and the comp is over heating, rec to start unit and check to see if the fan is running in the first 30-45 min, if not check cap or replace fan motor.
Posted on Jul 18, 2010
My AC model is Blue Star 1.5 ton 5 star inverter split AC. ODU is switching off when temperature reach its setpoint, but not the IDU. Does any one help me why it is so?
You likely are running a constant fan. Fan should be set for auto, this means it turns off when compressor turns off.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 14, 2017 | Star Heating & Cooling
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
Wiring standard for Split AC 1.5 Ton
The factor that you have not included here is the distance from the power panel to the unit...if it is too far then you need to up gauge the wire to compensate for that... that could be why the electrician wanted to go to the 720 ga. wire.
heatman101
Apr 16, 2010 | Samsung AS18A6RB Air Conditioner
LG split AC LST243H-2 not working at all,failed while on
i want purchase a split ac 1.5 ton our temperature may month 45 to 46 C which brand Ac purchse
Dec 29, 2009 | LG Heating & Cooling
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
AC is not cooling
I would say you have a freon leak. May be the outside unit is not running now because the low psi switch has it off because it does not have enought freon.
Apr 07, 2009 | Haier Air Conditioner
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
365 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
