Have got wireless router Cable/DSL 54 Mbps (WGR614). It is currently next to the TV (have Virgin Media). When Laptop is downstairs and not far away from it it works fine, but PC needs to be upstairs. Room is diagonally about 20ft away. Does not pick signal up, tried to move to room above where router is, does not pick signal up. WOrks fine once signal is picked up though (I moved the laptop to get a signal, then carried it upstairs, and it continued to work fine!), but soon as I logged off and re-booted, it did not pick signal up again. I dont know if it helps but have got cast iron SPiral Staircase - will this effect the signal. Any ideas on what I can do to get it working so I can use pc upstairs? Many thanks Eddy
    Scholar:
  • 176 Answers
You need to buy a modem booster or a acces point to boost the signal of your router .
Posted on Apr 21, 2008
NetGear wireless router WGR614 v6 runs with speed 1 0 mbps instead of 54 mbps
how far away are you from your wireless router when your getting 10 mbps?
Please note that wireless will not guarantee speeds of 54 mbps.
It will dramatically decrease the farther away you or how much interference there is between your laptop and router.
Also check if your wireless router is set to 802.11 G mode. if you have any devices that only support 802.11B you will only get speeds up to 11mbps compared to G at 54mbps
Mar 13, 2011 | Computers & Internet
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
Where do i find my networkkey
This is the network key you use in the router.
contact Virgin admin for this information.
Apr 23, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
I have a 20 mbps adsl line, but whene i connect the 3com 3crwe554g72 router wireless i only get 2 mbps , why?
This issue is most likely due to the quality of the signal between the PC and the wireless. If there is a lot of interference or the wireless devices are far from the 3COM, then the signal will be less then optimal. Sinnal quality will degrade quickly when going through walls floors and celings as the density and metal contained in these structures block wireless signals. Interference can come form other wireless devices, cordless phones, RC toys and some wireless mice and keyboards.
The other factor to consider is the type of wireless being used. Wireless like all technology get better as time goes by. As new technology comes out it is categorized and classified. For Wifi there are currently 5 separate specifications for wireless. They are:
802.11 (Specless) - approx 1997 era devices. operates at 1 to 2 Mbps
802.11 a - approx 1999. operates at 6Mbps.
802.11 b - approx 1999. operates at 11 Mbps.
802.11 g - approx 2003. operates at 54 Mbps
802.11 n - October 2009. operates at 100+ Mbps
If you have an old wireless device it will work with the 3COM but only at the speed it was designed for.
You can always check your speed by connecting directly to the 3COM with ethernet cable and going to http://www.speakeasy.net/speedtest/
Feb 05, 2010 | 3Com OfficeConnect Wireless Cable/DSL...
Laptop picks up wireless network but will not connect
Is the network secured? Do you need to enter a PIN or security passphrase? Is the router broadcasting Wireless-N and your adapter is not compatible? (Wireless-b/g?)
Dec 26, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Lost instruction
Lost instruction - NetGear
Nov 05, 2009 | NetGear WGR614 Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Need network key for NETGEAR (virgin) to connect
for that you have to access your router.
connect your router to computer with ehternet cable.
then access it with following link.
http://192.168.1.1
or http://192.168.0.1
type user as 'admin' and password as "admin" or blank or 'password'
then go to wireless security then you find WEP or WAP key there but it is in * or # format so you can't know it.
So you have to set new key so you can easily know it.
Then set new network key then save and restart the router then you can connect it with new key.
Aug 22, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Switched from comcast digital cable internet service to at&t dsl. got the motorola 2210 modem from at&t. am ok with just internet through the motorola modem. problem occurs when I attempt to...
Apparently the issue is caused because the motorola 2210 is also a router. To solve the problem the motorola must first be placed in "bridge" mode. Complete steps are available at: http://www.dslreports.com/faq/15855
Aug 01, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Signal Problems
try to bring another laptop to the location where you are having problem and see if the other laptop will have the same problem. if thats the case the problem is with the router. You can try upgrading the router's firmware or change the wireless channel
Apr 21, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
