Question about Whirlpool LEB6300 Electric Dryer
No heat in dryer
Everything works on the dryer there just isnt any heat
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;l'l;
Posted on Mar 04, 2011
Duet gas gas dryer has no heat
does the flame go on and then shut down if so make sure vent hose is clear all the way through if ok then you need to locate the blower wheel and make sure there isnt a sock jambed in it and its tight on the shaft not spinning loose they crack and are servicable.
Aug 28, 2012 | Whirlpool GGW9200L Gas Dryer
My maytag mdg5500 dryer isnt heating up. It all works but no heat.
Thier are several things that could cause a gas dryer to not heat, i have written a tip covering the most common ones http://www1.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Oct 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer isnt heating.
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Bosch Nexxt 500 Plus Dryer
Everything works but the clothes dont dry i changed the coils but that didnt do anything. i notice the ignighter isnt lighting up could it be that.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 10, 2011 | Kenmore Dryers
My dryer isnt heating
heatman101
Dec 15, 2010 | Amana NED7200TW Electric Dryer
Dryer spins but isnt heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 21, 2010 | Kenmore 700 7973 Dryer
The everything in the dryer is running fine but the heat isnt working
heatman101
Oct 14, 2010 | General Electric DBSR463EGWW Dryer
The dryer isnt heating up
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 21, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer willl tumble but does not heat up I worked fine last time
first thing go to elc panel breaker box make sure breaker isnt triped if it isnt u either have a heating coil out or the heat sensor out
Oct 23, 2009 | Dryers
Ariston washer/dryer. Dryer not working
Assuming everything else is working, it sounds like your heating element is burned out. Two years is a little short for the typical life span but not unthinkable.
Here's a photo of the part for your unit at a site that sells them. If you pull the back panel off and trace the wires, you should be able to find this part easily. It is designed to be replaced.
Sep 23, 2008 | Dryers
Whirlpool LEB6300 Electric Dryer Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
