Question about Kettler Cycling
I just installed a brand new Kettler ergometer axiom p2
I just installed a brand new ergometer axiom p2 but when I cycle, all parameters remain on zero instead of showing various values showing the effort.
  • 1,514 Answers
If this is a bicycle computer you're talking about there's a little magnet that has to be installed on the spokes of the wheel. It passes within 1 millimetre of a receiver which should be placed on the bicycle forks. Everytime the wheel turns the magnet passes a signal through the receiver to the computer which operates the computer. If the magnet is not tight enough it will turn away from the receiver and will not work. If it passes more than 1 mm from the receiver it won't work.
Posted on Jul 17, 2010
I have johnson jet 7000 treadmill and its showing error 2 what can i do
HI,
Error 2 means P0 P1 P2 P4 P5 ( P0 ....Min. ,Speed P1 ....Max, Speed P2 ....Mid.Speed, P4 ....Min.Slope, P5 ....Max.Slope )have a wrong parameter values. You have to go the engineering mode and set the parameter. Here i have added a link which will guide you to the service manual of Jet 7000. read the section 4 (console maintenance mode guide) and re-calibrate the treadmill parameters P0 P1 P2 P4 P5 .page no(4.3).
http://www.cross-ir.com/Downloads/JET7000-6000-1.PDF
WWW.electro-medical.blogspot.com
Sep 16, 2015 | Exercise & Fitness
Power Supply
Try emailing the parts department at Kettler USA: Kettler USA online shopping for tricycles pedal tractors ellipticals...
I used to have to contact them when I repaired Kettlers at the bike shop.
Feb 25, 2014 | Kettler Ergo Racer GT Indoor Cycling Bike
Treadmill KETTLER PACER - dc6 system fault, what I
Check if the drive motor is working
Power cycle...if still do not function calibrate or call 877-805-1030
Aug 10, 2013 | Kettler Exercise & Fitness
I have heard that Kettler highchairs are quite popular. What makes them so good and where can I buy one?
Kettler is a great brand of high chair. Most of these wooden high chairs are designed to grow with your child from infancy through their toddler years. I have found a few online stores that sell Kettler high chairs for you; although I strongly urge you to go to a retail store and see one for yourself.
http://www.healthchecksystems.com/kettler_high_chairs.htm
http://www.toysrus.com/product/index.jsp?productId=3559726
http://www.albeebaby.com/kettler-junior-high-chair-mahogany.html
Jul 19, 2012 | Baby Gear
Is there a place to buy a replacement wheel/tire for the Kettler El Toro 12" bike? My husband ran over the bike and bent the wheel and it is flat!
Of course there is, but if you can't find the same brand you can replaced it with other brands as long as the same size.
Apr 10, 2011 | Kettler KT902129 12" El Toro Bicycle
My friend gave me a Kettler Boston XL Treadmill (Germany) a month ago I only realize i m missing some info. Can you let me know what is the voltage for this brand. Fyi this unit was used on vessel and i hv...
there should be a model tag on the machine , probably down near the belt , that will have the voltage details for the motor
if not the plate on the motor will have the voltage , rpms, watts and cycles plate on it
Nov 24, 2010 | Kettler Exercise & Fitness
I have a Kettler ergorace spinning bike which measures, amongst other things, recovery heart rate over a 1 minute period and then gives a 'Fitness Mark', but nowhere in the instructions does it say what...
from
http://access.kettlerusa.com/retail/manuals/fitness/crosstrainers/7653-309.A.pdf
you'll find that -------------- The computer calculates and assesses the difference between load pulse and recovery pulse and your resulting "fitness value" on the basis of the following formula:
Note ( F ) = 6 - (10 x ( P1 - P2 )/P1)^2
P1 = load pulse P2 = recovery pulse Value 1 = very good Value 6 = unsatisfactory The comparison of load and recovery pulse is a simple and fast method to control your physical fitness. The fitness value is a value of orientation with regard to your ability to recover after physical load. Before you press the recovery pulse button and have the computer calculate your fitness value you should train in your load range for a longer time, this means for at least 10 minutes. With regular cardiovascular training you will notice that your "fitness value" will improve --------------
Nov 23, 2010 | Kettler Ergo Racer GT Indoor Cycling Bike
Manual for Kettler Ergometer CTR1
You can get the manual on the link below.
http://www.kettlerusa.com/CTR1.pdf
Good Luck and please rate
Jun 13, 2010 | Kettler Mondeo Elliptical Trainer
Servicing
Locate where the noise is coming from, chances are the bearings have gone bad go to Kettler fitness.com they have contact info on their web site.
May 16, 2010 | Kettler Ergo Racer GT Indoor Cycling Bike
Cycling Logo
297 people viewed this question
Top Kettler Cycling Experts
Tom Chichester
Donald Ayers-Marsh
Vern Reece
Vern Reece
Level 1 Expert
Are you a Kettler Cycling Expert? Answer questions, earn points and help others
