Question about RoyalTek RBT-2100 GPS Receiver
I got RoyalTek RBT-2100LP. It works fine with Laptop with Toshiba Bluetooth fine on Com 40. It works flawlessly with Nokia devices like 6700c etc without any intervention. Yet it repeatedly failed with WM 5 Smartphones fromHTC like S310 and S260. Seemingly pairing is successful? yet the apps tried did not work. Simply no data comes. Help would be appreciated. Thank you so much.
Will the bsh-100 pair with Iphone4s?
Yes. Starting with the iPhone 4 and newer, all support the following Bluetooth Profiles: A2DP(high fidelity stereo sound for music) , AVRCP(remote control, letting a headset's buttons change tracks, volume, etc), Handsfree and Headset(answer and make calls using the headset) , PAN (tethering a laptop to your cellular data conndction), PBAP (allows access to your contacts/phone book), HID (let's you use input devices like Bluetooth keyboards to type on your phone), and MAP (lets a bluetooth device send texts and get alerts if you receive one). Any bluetooth device with any of those profiles will work.
The BSH-100 uses the A2DP, AVRCP, Handsfree and Headset profiles, all of which your iphone supports. So all features will be enabled and work flawlessly on your phone.
Mar 06, 2015 | Anycom BSH-100 Bluetooth Headset
Unlocking code for nokia 6700c-1
Hi is your Nokia 6700c mobile is locked to one particular network provider .Then code is the best method to unlock it .To get code visit Simpleunlocking.com here they ask you the country name from where you bought your mobile ,network name to which your mobile is locked and the IMEI number of your mobile.Then they deliver you code to unlock your mobile.
Dec 06, 2012 | Nokia 6700 Classic 6700c Phone 5mp Fm Gps...
My nokia 67006-1 is model and code is 0584986 how to unlock?
You can unlock your Nokia 6700 or 6700C using unlock code. You can get the unlock code for your mobile from www.unlocking4u.com at affordable cost with easy step by step guide on unlocking process.
Jul 11, 2012 | Nokia 6700 Classic 6700c Phone 5mp Fm Gps...
Restriction Code required plz Nokia 6700 c IMEI is
You can get the restriction code from here
Theunlockarena.com
and Unlock Nokia 6700C
Nov 16, 2011 | Nokia 6700 Classic Cell Phone
Lost my CD driver for OUR PC RoyalTek RBT 2100 GPS BLUETOOTH Receiver
Greetings,
You can download the software from the Royaltek Discontinued AP Download site at
http://www.royaltek.com/index.php/ap-download/discontinued
Apr 18, 2011 | Computers & Internet
Dell 1015 vostro with window 7 operating and toshiba bluetooth does not detect bluetoooth of nokia 2730 and " device is not dected" even though everything tried it my best of knowledge and...
this laptop good buy, but the problem your having might be a driver problem. the interface is bluetooth not usb. you might need the mew drivers from nokia for windows 7 and use the usb cable to initially instal the drivers instead of the bluetooth.
Jan 28, 2011 | Dell Vostro 1014 Laptop Computer
Can i have how to connect Nokia BH-214 bluetooth headset pair in acer laptop(Asper5742)
from OFF state of your BH-214, press power button until LED flashes quickly,do not unhold, stay holding & press power button until LED flashes red & blue alternately slowly.On ur PC,->Add new device, then your PC would detect BH-214 as headset. I used Toshiba Bluetooth stack v7.00.10(T) driver Win7x64 (search in google to download the installer), work fine with my BH-214 to connect with PC (A2DP 1.2 (btooth audio profile) & AVRCP (player navigation control profile)) & at the same time with my phone (HFP, HandsFree profile). Applied CSR bluetooth dongle 2.0, got from store for only $2.50.
Jan 04, 2011 | Nokia BH-214 Bluetooth Stereo Headset
BT GPS module RBT-2100LP stuck in pair mode
royaltek faq advises to disconnect battery for 3 days to reset device
Mar 17, 2010 | RoyalTek RBT-2100 GPS Receiver
Sony TXN17P Bluetooth vagaries
Hmmm...
If you can connect manually but it is not connecting automatically, then you have a settings problem either on the phone (less likely) or within the applet on your laptop controlling the bluetooth services. Try that first before reverting to the XP bluetooth software; usually when companies include custom bluetooth software, it is necessary.
If you cannot connect at all...
If you have tried to pair the laptop with the Nokia using the Toshiba applet and it never seems to work, and you've tried adjusting the settings on the phone and in the applet, and you know the bluetooth card is on and running normally on the laptop, I'd suggest uninstalling the Toshiba drivers and software through CONTROL PANEL and then rebooting and see if XP takes control of the bluetooth adapter. If not, try uninstalling the bluetooth hardware in DEVICE MANAGER and then rebooting, which will force XP to do a clean install (including bluetooth support software) and see if this gets you to normal operation under XP. If not, go to the SONY web site and, again, do a clean install of their bluetooth support software for your model, and try again from there. One of these combinations is pretty sure to work.
Make sure that if your laptop has a physical button on it to activate the bluetooth radio, that it is on, and that the device is enabled through device manager/network/connectivity. Any one of these being mis-set can (especially on Sonys) result in a confusing set of inexplicable failure conditions.
Good luck...
Nov 17, 2007 | Computers & Internet
RoyalTek RBT-2100 GPS Receiver Logo
330 people viewed this question
Top RoyalTek GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a RoyalTek GPS Expert? Answer questions, earn points and help others
