Question about Samsung S3650 Corby / S3650 Genio Touch Cell Phone
USING SAMSUNG CORBY PRO CONNECTING WIFI GETTING ERROR NO RESPONSE FROM AP.I HAVE PUT ALL IP/GATEWAY OF WIFI ROUTER
I already connect to wifi but when i want to access internet it says no response ...
Posted on Oct 18, 2012
5 Suggested Answers
  • 180 Answers
SOURCE: how to set up GPS and map and wifi in corby pro
I will tell you how to set up wifi in corby 1st because it will come in handy in the second part.
1) 1 st go to menu and scroll to the right screen where the wifi shortcut is detected.r phon
2)Click on wifi and it will open and then click on the grey bubble which says wifi, this will activate your wifi.
3)Now click on search, and now your phone will search for available wifi signals.
4) If a wifi signal is available click on it and click connect. If you are accessing wifi from this source for the first time a window will pop up describing the wifi settings, now click on save and it will be saved.If the connection is a secured connection you will have to insert the password in the details
5) After saving the settings your phone will be connected to the network.
6) Once it is connected click on the wifi provider link and click start internet, now you can browse internet using wifi
To set up your gps
1) Go to menu click on settings
2) In settings go to phone settings
3)Select GPS settings
4)click on GPS + settingsr
5)Click on download data and then the phone will download data for your gps, you have to choose a profile for downloading the gps data that is whether if you are using gprs or wifi. Click the profile and you are done .
6)You will download data and to check position click on gps position in gps settings menu
Posted on Jun 20, 2010
  • 296 Answers
SOURCE: how to connect samsung 3g to bsnl wifi?????
check your access point settings maybe you entered a wrong configuration, or ask the right configuration from you network provider. no response means, either there is something wrong with your configuration or there your ip have too much traffic.
Posted on Feb 17, 2010
SOURCE: samsung s5560 cant connect tto wifi, phone comes
it's saying i need a password ?
Posted on Apr 25, 2010
joemxavier
  • 342 Answers
SOURCE: hi... i just recently acquired this samsung corby
The AP & DNS means a code which makes your mobile registered.the dns and ap address will be getted from the wifi connection center .
Posted on Jul 05, 2010
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
Steps to activate or to connect wif using this samsung gt-b5310
Thanks, bigbadbry69. My samilar issue was resolved by following the suggestion!
Just remind here the "WEP password" is from router and put into mobile's "Network Key" field (WIFIi->search/select connection -> scroll down to Network Key).
Sep 11, 2012 | Samsung GT-B5310 Corby Pro GSM Slider...
I am not able to understand how to use the wi-fi in my samsung corby pro mobile
you need to understand two things.
Wifi is a service which requires an access point i.e. a Access point hardware, also known as Wifi Router and A wifi enabled phone. As you hve mentioned that you have corby- pro, it does have a wifi chip to access the wifi signal. Now you must get a wifi access point, i.e. a Wifi router, d link has veriety of routers, Now connect the router with broadband internet line and enable it. Configure the router through your desktop.
Now switch on the wifi on the corby pro and establish connection between the wifi router and corby . Then only you will be able to connect with internet..
Dec 01, 2010 | Cell Phones
DNS FAiLED thats only the problem .. i can connect to wifi but when i start typing the url then enter go ..the response is dns failed
It is a problem due to DNS server ip address.If you configured ip address in mobile manually to connect wifi check the DNS address.If you have connected to wifi automatically means there is a problem of DNS ip in the wifi router configuration.Google has public dns of 8.8.8.8 if possible configure in Mobile and try it
Oct 28, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How to download games in samsung corby pro?
Requirements: LAPTOP/PC with wifi support
First of all please set the default storage to memory card for WAP Downloads in your corby pro.
1. Get all the jar files, mp3, mp4, flash objects etc and store it in a directory on your laptop/PC which you want to download to your corby pro
2. Make that directory a Virual directory in Personal Web server of IIS in XP.
3. GO to IIS - Default Web Site - Properties - HTTP headers - MIME File Types
4. Add the following 2 new file types so that your PC/LAPTOP becomes a WAP GATEWAY !!!
a. Associated Extension: .jad, Content Type: text/vnd.sun.j2me.app-descriptor
b. Associated Extension: .jar, Content Type: application/java-archive
5. Get the JADMAKER.exe available freely on internet.
6. Use jadmaker to get jad file out of the jar files.
7. put both jad and jar in the same directory which is virtual directory in personal web server of IIS.
8. Assign IP address 192.168.0.1 and subnet mask 255.255.255.0 to your laptop/pc wifi card
9. Assign IP address 192.168.0.2 and subnet mask 255.255.255.0 to your Corby Pro
10. Point the corby pro browser to 192.168.0.1/corby, where corby is the virtual directory configured in IIS pointing to actual directory.
11. You will get the list of files on your corby pro browser, select the jad file of the game/application and see the message you are getting , Go Ahead !!!
Now you can download the contents from your laptop or pc exactly in the same way as if you are downloading it from mobile operators without paying the network charges.
May 18, 2010 | Cell Phones
Wi-fi connection problem
There are 2 ways to approach your problem.
  1. Un-protect your wifi connection by removing the password. This is risky since other wifi gadgets can readily connect to your network.
  2. Configure your Samsung phone to connect to your password-protected wifi. Make sure that the wifi protocol of your phone matches that of your wifi router. Example, make sure to set WPA or WPA2 on both device.
May 08, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How to connect samsung 3g to bsnl wifi?????
Feb 11, 2010 | Samsung Jet S8000 Cell Phone
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
My laptop will no longer connect to my wireless router but my desktop still has online service.
check your laptop wifi , are you sure that is on, search wifi , you must saw wifi ap in your windows, so click connect with wifi that is choose, if your set is in automatic ip gateway and dns server , you must take on your dhcp mode in your router, if itsn set your ip in permanen value
Sep 26, 2008 | Gateway Computers & Internet
Samsung S3650 Corby / S3650 Genio Touch Cell Phone Logo
789 people viewed this question
Top Samsung Cell Phones Experts
John Tripp
John Tripp
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
