Question about LG LSC26905TT Side by Side Refrigerator
Lg gr-329bv not cooling.
My LG fridge model GR-329BV is not cooling. It uses a blowing agent. It comes on.
SOURCE: LG GR-602TVF Top Freezer
turned out to be the compressor all fixed and working fine now
Posted on Feb 26, 2007
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
Benimur
  • 6966 Answers
SOURCE: refrigerator not cooling.
Hi and welcome to FixYa,
Almost always, your described problem could be either:
  • evaporator fan/blower is faulty; or
  • air passgaeway blocked or vent is blocked or closed.
The refrigerator section gets its cold air from the freezer. If the freezer is working then the frozen air would have to be drawn to the refrigerator side by the fan. If the fan is not working or the air passage way is blocked, then no frozen air would be moving towards the refrigerator side. result would be as you described.
In some instances, it could be the thermostat of the refrigerator but this would be least likely.
Good luck and thank you for using FixYa.
Posted on Feb 22, 2009
  • 400 Answers
SOURCE: LG GR-292R freezer works/fridge does not.
It is more than likely short of refrigerant, needs to have the leak repaired and then recharge refrigerant.
Posted on Mar 05, 2009
Lg fridge GR-B3993LQ is not cooling
Make sure that the thermostat is working and that the compressor and associated fans are working (getting Power).
If both units are working and still no cooling your evaporator could be frozen because the defrost timer/element is not working. Worst case scenario is that you may have developed a small leak and lost refrigerant.
Mar 11, 2015 | LG Refrigerators
Defy refrigerator gr-329bv is not getting cold enough. the freezer part is working like a bom. but the fridge part is not making cold enough. Please help
If your refrigerator is not new, it might need to have the area under the front of the refrigerator cleaned out anything that may be blocking the airflow from the fan.
Sometimes that works but there ma be a problem with the thermostat.
Hope this is the information you need.
Jan 28, 2015 | Refrigerators
I have LG Electrocool GR-252SQ(Double door).the freezer is very cool but the lower fridge section is not getting cool.Plz guide.
i have same fridge and my problem is that the water from freezer is not going out pf the fridge, instead it comes down to fridge section through condensation
Mar 24, 2013 | Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
87 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
