Question about Saeco INCANTO DELUXE Espresso Machine
Hi my incanto does not do a few things, firstly it grinds coffee but doesn't give any, secondly it tells me to ventilate but won't,what can i do? thanks.Pezza
  • pezza57 Jul 17, 2010
    Thanks for your reaction, but it has now gone back to ther message ready for use! only thing is now when i take the brew unit out sometimes it will give a coffee and sometimes it won't, i'm thinking it's blocked or maybe it's not sitting right because it only happens when the unit has been in and out!
  • Saeco Master
  • 1,711 Answers
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Posted on Jul 17, 2010
Beans grind and are wet but coffee doesn't come out... it goes through the cycle and spits out a little. When cycle is complete, the water light comes on, but after priming the same thing occurs.
This tells me that either the grind is too fine and or the brew unit screen, and discharge tube needs to be cleaned. Try this first press the button for making a espresso using the manual function, do not add coffee through the door then press the brew button. If water flows freely then the grind is too fine, if you get the water prime error then the screen under the red o-ring on the brew unit needs to be cleaned.
Oct 19, 2011 | Saeco Incanto Classic Espresso Machine
I have a Saeco Incanto Classic.\r\nI have noticed the grind 'cakes' in the dregdrawer have become very sloppy. When I first owned the machine the cakes were dry & compacted and easily removed. Now I...
HI
The first thing you need to do is increase the amount of coffee going into the brw unit. Turn the small knob up towards the plus+ but 1 mark from the full +. This will take up the air space the water is occuping and then see if you have a sloppy puck. If you still do your grind is to coarse and needs to be tiurned down but never lower than 6 and only when grinding. If you grind doesn't change ( remember it takes 3 cycles to change the grind in the brew unit) your grinder may be bad.
Feb 01, 2011 | Saeco Incanto Classic Espresso Machine
Make coffee stronger on a saeco machine
Hi, adjust coffee amount knob more towards +, which will grind more coffee for brewing. The knob is the smaller one inside the bean hopper.If the machine has digital display(Incanto Deluxe) it can be set in the menu.
Jul 29, 2010 | Saeco Incanto Coffee Maker
Coffee beans out of message
HI
I hate to tell you this but your grinder is bad. The sensor in the grinder is messed up, and thinks its done grinding after 3 seconds. The grinder will have to be replaced. Sorry
Dec 16, 2009 | Saeco Incanto Sirius Fully Automatic...
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic - Bean feed problem
First, make sure you not get any damp into your grinder.
If you get damp into the grinder then it will not grind the beans.
To check the grinder you have to loosen the three screws in the beanhopper and lift it up.
The jagged plastic in the machine you will see when the beanhopper is off, turn it anticlockwise to you can see
the claque is free, then you can take out the jagged plastic and you will see the grinding wheel, make sure the wheel and the jagged plastic is clean.
Before you mount all again, use a vacuum cleaner to clean it.
Put back the jagged plastic again and turn it clockwise to it stop, then you turn it anti clockwise 14"click".
Set the number to 8 on the beanhopper and mount it again.
Hope this will help you.
Best regards
/Mirran
Aug 29, 2008 | Saeco Incanto Classic Espresso Machine
Incanto Calssic
Best regards
/Mirran
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco incanto rapid steam Model #SUP 021yr
Try to clean the brewing unit and make sure the filters is clean.
/Mirran
Aug 21, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Jul 19, 2008 | Coffee Makers & Espresso Machines
Saeco INCANTO DELUXE Espresso Machine Logo
220 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
