Question about GPS
How can I find the poblem to why my headlight and fog lights on the driver side is not coming on. I change the light bulbs I also looked to find the fuse box with the headlight indicator but was unsuccessful. How many fuse box are there in this vehicle and where can I find them?
  • 1,557 Answers
If one side is working but the other isnt its not a fuse. its a link problem. headlights are wired in positive polarity its either a broken wire or possibly a downed relay. start there.
hope helps
Posted on Jul 17, 2010
2006 Pontiac vibe, left side headlights (both) and fog lamps did not come on...replaced the headlight bulb and everything worked normally
Perhaps, but your replacement of a headlight bulb would not have "fixed" the other light outages, unless there is a sensor that can tell it was out and therefore, shuts every other light off until it is fixed. A little more likely is the action of moving things to replace the light temporarily "fixed" a bad connection at or near the bulb socket. If it happens again, you will have a clue to the location. It may also be some effect on the headlight relays.
Mar 10, 2015 | 2006 Pontiac Vibe
Headlight fault
You may have blown a fuse, check fuses first then before you try to replace the bulb again check for broken wires or the correct bulb
Oct 25, 2017 | 2008 Kia Pro-ceed 1.6
Install problem with h3 fog light bulb for 2002 wrangler
If it is a double filament bulb, try to rotate by 180 degrees in base, since there is a difference in power and touch of the bottom pins
Sep 10, 2017 | Jeep Wrangler Cars & Trucks
Headlight come on , replace dimmer bulb but light comes on and goes back out. could it be relay or switch itself. The light and fog light work on driver side but not passenger side. IThis problem occur...
it sounds as though there is a loose connection on the passenger side. Check socket and switch bulbs from driver and passenger side. hope this helps tim
Sep 05, 2010 | 2001 Hyundai XG300
2008 hhr ls can't get to drivers side headlight bulb to change Please help?
This video will show you how to replace the headlight and also the bulb in the headlight of your HHR">
May 20, 2010 | 2008 Chevrolet Hhr
HOW DO YOU CHANGE THE BULBS OF THE FOG LIGHTS?
The fog lights on most vehicles sit directly underneath the headlight bulbs. The ballast and wiring work just like the headlights, so changing them takes not much time. The procedure to change the fog light is as follows:-- 1) Open the hood and reach down underneath the headlights to unplug the electrical plug from the fog light assembly. Squeeze the top of the release tab and pull the connection off the bulb's ballast. 2)Turn the fog light counterclockwise to remove it from the fog light housing. 3)Install the new fog light bulb.Then connect electrical plugs properly. 4) Test the fog lights by turning it ON. Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2002 GMC Yukon XL
How do u change a bulb in the fog lights on a
May 20, 2010 | 2003 Ford Focus
What size bulb is an audi s4 headlight and fog light?
SYLVANIA H7 SILVERSTAR HIGH PERFORMANCE HALOGEN HEADLIGHT BULB -- 55 Watts, Single C-8 filament for use as either high beam or low beam; 100 percent legal halogen headlight bulbs; Features the whitest and brightest light colour similar to daylight for safer night driving; Meets all US FMVSS 108 and Canadian CMVSS 108 requirements. Fits Driver or Passenger Side Driver or Passenger Side Fits the following vehicle/s
2004 Audi S4 Base 8 Cyl 4.2L 2004: Base; 8 Cyl 4.2L RAMPAGE FOG LIGHT, BLACK METAL HOUSING, With round clear lens; Includes 100-Watt H3 halogen bulb, one lamp and a single bolt mounting system; Provides better illumination Fog Light
  • Fits the following vehicle/s: 2004 Audi S4 Base 8 Cyl 4.2L 2004: Base; 8 Cyl 4.2L;
Jun 24, 2009 | 2004 Audi S4
How to change fog light bulb
Open the engine hood and you'll see there is a plastic housing holding the head light ans side light to the frame. There are two wing nuts and one wing bolt holding it all together. Remove those and pull the headlight and side light housings out from the frame. You'll be able to access all of the lights now.
Jun 10, 2009 | 2002 Pontiac Montana
How to replace bulb for fog on the front .
You can access it from behind.You have to remove splash shield and go from the underside.
Nov 12, 2008 | 1999 Lexus RX 300
GPS Logo
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
