Question about Soyo DYLT032C 32 in. LCD Television
My tv won't turn on. When it is plugged in the blue light on the front flashes and the tv is otherwise non-responsive.
  • 96 Answers
CHECK THE FUSE
Posted on Jul 17, 2010
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Visio light on front flashes on and off tv won't come on
Unplug your TV and then plug it back in, let it flash on and off without doing anything for 5 minutes or so and then turn it on. It does it once amonth or so for some reason.
Nov 24, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
TV wont turn on????
Some models may have a small little hole in the back to reset the TV if not I believe it may burn out on you.
Have it chec by your localTV repair man
Jun 29, 2010 | Philips 50PL9126D/37B 50" DLP TV
61md10 front panel controls lit uo, but the TV does not respond
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
Aug 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
TV won't power off and on. There's a flashing red light but TV is non-responsive.
Try disconnecting the TV from the power socket, leave it for few hours and then plug it back and then turn TV on.
If your TV starts working..great..but if it happens again then you might have problem with the power supply board in which case you will need to get it repaired.
Jul 07, 2009 | JVC TV-20241 20 in. TV/VCR Combo
My panasonic viera tv has blown its 5amp fuse. i have replaced fuse but now it will not start up the front red light flashes but the fan does not start up and there is no picture can u help
My problem is exactly the same. The TV blew its fuse and will not start again. The front red light flashes when we press the remote but otherwise there is no response.
Aug 18, 2008 | Panasonic Televison & Video
Soyo DYLT032C 32 in. LCD Television Logo
214 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
