Question about HP LaserJet 4350 Printer
Hp 4350 error code 50.3
Can you help me fix this problem my printer showing 50.3 error i was changed new fuser but still same error thanks master
  • Anonymous Mar 19, 2014
    after about 3 hours of nonuse error code shows and I must turn off and turn on printer for operation
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Posted on May 28, 2008
    New Friend:
  • 159 Answers
Control panel message Description Recommended action
50.X FUSER ERROR
For help press
A fuser error has occurred.
X Description
1 low fuser temperature
2 fuser warmup service
3 fuser over temperature
4 faulty fuser
5 incorrect fuser is installed
6 open fuser circuit
1 Turn the printer off and allow it to cool
down.
2 Verify that the correct model of fuser is
installed.
3 Verify that the correct voltage fuser is
installed.
4 Reinstall the fuser, and check the
connection between the fuser and the
printer. Replace the connector if it is
damaged.
5 Replace the fuser.
6 Replace the dc controller PCA. See
Dc controller PCA.
7 Replace the power-supply assembly.
See Power supply.
Posted on Apr 24, 2008
  • 14 Answers
Ok, this will cover number 2 and 3 above. a lot of 3rd party vendors ship the wrong fuser out. remove the fuser, check the white label, and make sure the part number reads RM1-1082 xxx. any other number, and you have the wrong fuser. also, place your original fuser back in. if you have the same error that your replacement fuser is giving you (and both have part number RM1-1082 on them), then replace the power supply assembly (RM1-1070-040CN), and if that doesn't work, then do a DC controller (RM1-1108-130CN). best of luck.
Posted on Apr 28, 2008
If you need a fuser call this guys at <a rel='nofollow' href="http://www.netEffx.com">www.neteffx.com</a>
Posted on May 02, 2008
Hp laser jet 4350 printer clearing paper path error
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on either matrix from the link below and follow the steps. http://www.metrofuser.com/support/error-codes.html
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Comment back if you need more help.
Thank you again for contacting FixYa.
Jun 09, 2011 | HP LaserJet 4350 Printer
For the HP 4350 laserjet DTN what is the error code 50.5 fusion error tell me. Is it an easy fix?
You need to replace the fuser lamp (or ceramic fuser) and the thermistor.
If you can get the replacement parts, it's an easy fix.
Nov 17, 2010 | HP Office Equipment & Supplies
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Error 50 code, have replaced fuser and checked connections
I am not sure this will stay fixed but after i cleaned the pcb's and checked the connections and let the unit sit overnight the printer works just fine. If this does not stay fixed I will contact you again.
Thank you,
Apr 14, 2009 | Office Equipment & Supplies
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
Hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Apr 15, 2008 | HP LaserJet 4350 Printer
HP 4350 printer, 49.2F9D service error
Your fuser element is faulty. Check both connectors, make sure they are nice and secure on the element. Still not working replace element.
Feb 12, 2008 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
10,962 people viewed this question
Ben Johnson
