Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
How much does a O.S. relay cost? it get short circuited,because some water went in it.
  • 384 Answers
Dear sir /madam
o.s realy is not so expensive ( its depend on your area or country) i mean it should be 10 us dollar (approx.) for furthe information please contect to your local area distributer/frenchizy .
hope answer the question
thank you
please vote
Posted on Jul 20, 2010
Does not cycle properly
if water valve still allows water even after unplugged electric wires to it then water cylinoid valve is bad.. if water stopes when unplugged then relay in circuit board is sticking or board defective..
Mar 26, 2014 | Hoshizaki Freezer Commercial Ice Machines...
We have the Delfield XL 6000 freezer. We have been having problems with the breaker keep fliping off and causing to loose food. We have had Delfield technicians to come out on several occasion and they...
Ok ,
Does it trip all the time now,or only after running a while.?
If it trips right when you reset breaker with machine OFF, have the wiring checked for a dead short to ground up to the thermostat.
If it trips after running ,as it starts or intermittently there's a dead short to ground that could be any where.
You can simulate what is going on by doing this check.
Unplug machine.
Using an ohm meter,set to ohms, place a test lead on the ground prong(round one) .Place the other test lead to one of the remaining prongs.If there is any reading youv'e got a short. Try the other prong as well
However, if you get no reading there still could be an intermittent short .
Another thing to check. It might not be the machine at all.
Sometimes,if your wall recepticle is worn or old it can heat up causing circuit breaker trip.
Make sure there are no extention cords involved.
If you're on a 15 amp circuit ,you might want to upgrade to 20
Good hunting
Aug 18, 2011 | Delfield Freezers
The solenoid on the compressor just clicks on and off without the compressor starting.
The compressor may be faulty or the relay may be faulty. A service call will cost about $100 to find out for sure. The relay costs $26.22, so I would recommend replacing the relay and see what happens.
Kelly
Mar 23, 2011 | Whirlpool Upright Freezer EV201NZR
Went of vacation and just returned to a puddle of
your ptc relay and contactor on the compressor body is defective,unplug the unit,remove the spring wire or clip that holds it onto the compressor and install a new one,also if it has a run capacitor replace this also
Mar 18, 2010 | Freezers
Whirlpool Freezer went from -18C to -3C over 2 weeks. Defrosted
Got my mate electronics exoert to check the circuit board, he found the fautly part and replaced it - cost ZERO
Jan 01, 2010 | Whirlpool Freezers
Frigidaire freezer not working
The thermostat may have shorted out so that it is no longer making contact to put power to the compressor. After drying out the components try bypassing the thermostat and see if it will start or make any sound whatsoever. If it does start and run with the thermostat bypassed replace the thermostat. 4-6 inches of water can also get to the relay on the compressor. Replacing the relay and over load assembly also be a good idea.
Sep 13, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Relay clicks, compressor doesn't start
try replacing the relay/ overload you can buy a supco replacement there's 2 of them one covers 1/15 - 1/6 and the other covers1/3 - 1/4 its really easy to wire up and cost effective. any questions don't hesitate to contact by e-mail hvac.tech@gmail.com
May 18, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Whirlpool AFB6640 freezer
Ive just revived one of these with similar symptoms that eventually died completley. A trawl of the internet shew that the most common fault is the SHRACK relay on the board. An Omron G5LE-14 relay is a better quality replacement at minimal cost. Its a ten minute job to replace it with a soldering iron. The RS part number is 369-488. However they are sniffy about dealing with non trade account holders by mail so if you dont have a trade counter nearby Rapid Electronics are a better bet (part number 60-4198). If you are really mean over postage there are also some ebayers offering the same part (e.g. lesjacksam) double check part numbers before going down that route though. Hope this helps somebody.
Apr 12, 2008 | Freezers
Hoshizaki Ice Machine starting problem after shut off
I am guessing there is a safety switch somewhere which is gauging how much water is left in a defrost tray. Other likely things: open circuit breaker from the water shorting things out. Start with these. Other, more exotic things could be involved...but not as likely as the above.
Dec 04, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Freezers Logo
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
