Question about Nokia N73 Cellular Phone
N73 when charging phone restart
Nokia n73 not turning on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 16, 2013 | Nokia N73 Cellular Phone
Nokia n73 restart problem
Hello and Welcome to FivYa!
Well, the restart problem could be due to numerous reasons:
Software bug/ Mal function.
Hardware Error ( main board faulty)
Improper charging/ weak charging IC, battery.
You need to sort out each possibility one by one to trouble shoot the problem.
Concerned.
Jun 29, 2011 | Nokia Lands Phones
My N73 is saying memory full delete some data, but my phone memory is empty what to do ?
You have to reset the phone to solve this problem. To reset the phone:
1. Please make sure the battery is fully charged.
2. Take a backup of contacts and messages because these may get removed during reset.
3. Press *#7370# and then enter security code. (Default is 12345)
4. After the phone restarts, restore the backup.
That's it, your problem will be solved.
Don't forget to rate me.
Thanks for using FixYa.
Jan 15, 2011 | Nokia N73 Cellular Phone
NOKIA N73 UPDATE BUT NOT SWITCH ON
Take out battery for at least 30 min, restart your PC and connect again using different USB port.
Jun 10, 2009 | Nokia N73 Music Edition Smartphone
Can't use the file transfermode for my nokia n73 with blue soleil
first u see ur bluetooth its hidden or shown to all its hidden change to shown to all then u recive datas.......................one more idea is there but u loss u r contacts u r phone memory fully cleared.....just press...........*#7370# .......they show restart u r mobile .........u want to restart ...then u give yes .....the default code is 12345..........but one condition u want to restart that mobile its fully charged ok....
May 10, 2009 | Nokia N73 Cellular Phone
N73 always restart
It is due to phone's software problem.Re installing your phone's software or updating your phone's firmware can fix the problem.
May 08, 2009 | Nokia N73 Cellular Phone
I updated n73 mobile it is not working
hi, i had this problemonce with the n95, i tried re installing the software, it took about 3 attempts but it did work
Jan 02, 2009 | Nokia N73 Cellular Phone
NOKIA N73 PROBLEMS
my n73 hand set problem is if i connect the charger on the screen displayed not charging, and i use to charge the battery charger to store power in battery. charger is working fine but hand set troubled me and the other problem is if i listen the music files after 2 minutes phone is off, in a day its happening lot of times give a complete repairing solutions.
Jul 16, 2008 | Nokia N73 Cellular Phone
My N73 is not charging
try to replace ur charger, coz charger not compatible to your phone.
Feb 07, 2008 | Nokia N70 Cellular Phone
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
