Question about Samsung SCX 4521F All-In-One Laser Printer
Samsung scx4521f scanner locked
Please tell wheather the scanner lock is under the machine or its under the sacnner tray
  • 2 more comments
  • vateruya May 08, 2008
    My scanner is too locked, i did not find this botton for unlocked .. Please, help-me.
    Where I find it???
  • banteng Aug 26, 2008
    the scanner locked under the scanner tray
  • SAT_YADAS Sep 03, 2008
    HOW TO SCANNER USE
    HOW TO SCANNER USE
My printer also scanner locked
Posted on Sep 08, 2010
I think the scanner is locked under the machine
Posted on Sep 28, 2008
  • 1,113 Answers
On ceiling of area directly above paper exit if no sorter is attached
Posted on Apr 21, 2008
    Genius:
  • 2,785 Answers
Generally under the machine
MACHINE
Posted on Feb 02, 2011
Scanner locked
the noise is your scanner the light trying to move, you probally have the scanner lock on or the scanner rail needs a lube or moter is stuffed, but good chance scanner lock is on.
Waste toner... clean the bottle... dont just empty it... most machines try to see threw the container to see if it is empty... if it has dust on the sides it cant see threw so thinks it is full
Feb 07, 2012 | Samsung CLX 3160fn All-In-One Printer
What does L1 mean?
That is a code telling you the scan lamp is not moving properly.
I wouild first of all go to the left side of the machine and look at the bottom of the scanner. On the bottom of the scanner there is a scan latch used for shipping purposes. Often times when you remove your pages from the output tray you hit it and lock the scanner.
I would think if you turn the machine off and be sure the scan lock is in the UNLOCKED position you will resolve your problem. If not leet me know please.
Aug 11, 2010 | Sharp AL-1642CS Copier
Plz tell me the flatbed scanner or pass through scanner is same type or different?
They are different.
A flatbed scanner works like the usual scanners you see - you put a document on a flat surface area and have it covered. Canon Lide is an example.
A pass through scanner works like the usual fax machine system wherein you will have the document to be scanned feed, and as it passes though the imaging part of the machine, it's digital copy is generated.
There are machines that works as both - Brother 185c and Samsung SCX4521F are examples of both flatbed and pass through scanners.
Jul 31, 2010 | Kodak i1220 Pass-Through Scanner
Scanner locked scx4521f
Turn the machine off. Look for a locking mechanism right above the area that copies exit out. There is usually a plastic knob that can be set to "lock' or "unlock". Rotate the knob to select "unlock" and this will release the scanner. You will have to look below the top frame and above the paper exit area.
Nov 08, 2009 | Samsung SCX-5115 Fax Machines
INNER TRAY
the inner tray is where the paper comes out under the top scanner part there is a paper sensor at the exit mark that tells you if you have paper in the tray and lets the machine know it has come out ok. check that it hasnt locked in place.. this can give a false reading too..Good luck
Oct 27, 2009 | Toshiba Office Equipment & Supplies
Samsung scx4521f saying scanner locked
under the operations panel, where the copies comes out there is an optic lock. You need to unlock it.
Sep 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Scx4521f scanner locked
just open the optics(transparent mirror) and try to take back scanner with ur hands and also check scanner belt is on the gear if it is not then put it on it as it is as the cycle chain
Apr 01, 2009 | Office Equipment & Supplies
The other lock
If the key is removed, the lock is gone from it.  It's just a clear piece of plastic in there.  What could be causing the L1 to happen is the ribbon cable underneath the scanner glass is out of place causing the scanner to stall.  This is a common problem with the AL copier line.  You can take the scanner glass off and check the cable for any binding going on with it.
Sep 07, 2008 | Sharp AL 1215 Black and White Copier
Scanner locked
There is a green lever on top of the output tray. Push it back to lock and pull it toward you to unlock the scanner. Hope this helps!
Jul 09, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
2,134 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
