Installed a ritetemp 6022 thermostat. Target temp is set to 76F and unit continues to operate in spite of ambiant temp. Reading 74F. Wiring has been double checked with manual. We have doubts about jumper settings.
3 Suggested Answers
  • 10 Answers
SOURCE: Need wiring to therostat to install a ritetemp
R-red W-heat G-fan BLUE-A/C R-red wire W- white wire G-green wire BLUE-blue wire
Posted on Sep 01, 2009
SOURCE: ritetemp 6022 programmation manuel Where can i
when the furance turns on it never shut off. how can I fix this.
Posted on Dec 18, 2009
I have a new lg mini split that fan runs continuous on indoor unit. Customer does not like this. Is there a way to change settings or add a hard wired tstat?
there is a problem in where the unit is installed ( too high) ,the setting for the temperature is too low( recommend 25 C, the doors and windows are open or the unit is too small for the room
the thermostat is in front of the evaporator and reads the incoming air temp so hard wiring a thermostat some where else will not turn the fan off
maybe your customer should have the ac unit operation explained
of course if it is a plug in power lead , it could always be turned off at the wall or if hard wired there should be a circuit breaker in the hard wired wire
Jul 11, 2017 | LG Heating & Cooling
Getting an E4 Code and the air is not as cool as the temperature reading indicates. How to fix?
I think it is low on gas. You will have to call the repairman on this one. If it is real old, just replace it.
Jun 09, 2015 | Heating & Cooling
What is the on/off temperature (heat) range for a RTH111 series
Heat range: 40 to 90 degrees F
Cool range: 50 to 99 degrees F
1 degree deadband
Here's the operation guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2603EF.pdf
Please mark my answer as helpful.
Jan 05, 2015 | Honeywell Digital Manual Heat/Cool...
My Ritetemp thermostat keeps going into override and blowing cool air when the heat is supposed to be on. Anyone know what im doing wrong?
Rite Temp thermostats don't usually work buy a Honeywell thermostat and wire correctly or call a tech. Be sure and mark original wiring or you will need to call a tech
Nov 13, 2014 | Heating & Cooling
Ritetemp 6022 programmation manuel Where can i
Dec 08, 2009 | Heating & Cooling
Need wiring to therostat to install a ritetemp 6022
Aug 31, 2009 | Heating & Cooling
Hard to start in morning
if it is carburated you need to adjust the fast idel and the choke if it is fuel injected try checking the temp on the coolant temp sensor with a scanner the temp might be reading wrong if it is differant than ambiant temp in the morning change sensor
Aug 15, 2009 | 1989 Toyota Corolla 2 Door
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
AC thermostat does not control AC. AC runs continuously. Have to shut system off to stop AC.
are you using the old coventional thermostat? using mercury
or was it digital?
chances are the reason it is not stopping because it can not detect the right temp inside your house, if you have set this for example 74F AC would run continouisly until it reaches that right temp, until that time, it would surely not stop,
check for any windows, door that might cause some air leaks inside your house for a start, close all exhaust fan and see if you can see any difference, if not this might be the right time to change for a digital temp control, it not that expensive and easy to install
Jul 25, 2008 | Heating & Cooling
Heating & Cooling Logo
394 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
