Question about Dryers
Doesnt use powerball, half dissolved tablet sits in bottom at end of wash.
  • bensmith6531 Apr 21, 2008
    Model is dishlex dx103
    Novelist:
  • 184 Answers
THIS IS LISTED AS A DRYER. IF THIS IS A DISHWASHER, CHECK TO BE SURE YOU HAVE A SUFFICIENT SUPPLY OF WATER. ALSO, CHECK TO BE SURE THAT THE WATER TEMP GOING INTO THE DISHWASHER IS 120 DEGREES FAHRENHEIT.
Posted on Apr 22, 2008
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
I went to take out my dishes out of the dishwasher this morning and the tablet was sitting at the bottom of the machine half disolved and most of my dishes weren't washed properly. What is the problem?
1. Check that water enters dishwasher.
2. Check that water is heated,tablet door will then open, this allows the propellor to shoot hot water at tablet to dissolve.
Apr 19, 2011 | Smeg 24 in. DWI612 Built-in Dishwasher
Power balls not disolving
Check what cycle you are using, the different sections of a powerball are designed to dissolve at different stages of the cycle so if the cycle you choose dont have the stage required it aint gonna work correctly. I think Eco and Fast washes affect them.
Hope this might help
Dec 03, 2009 | Microwave Ovens
Tablet is not dissolving from my dishwasher drawer
If it drops to the bottom when you open the dishwasher door - your soap dispenser is blocked by the rack or an utencil protruding from the rack. Make sure both racks slide in all the way to the back. (hint: check the middle spray arm inlet, make sure it aligns with the tube on back.
Good luck)
Oct 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
I have a Chef Classic dishwasher - not washing properly
The caddy for cutlery on this model is in front of the compartment where you put the tablets. What'll sometimes happen, is a spatula or wooden spoon or something in the caddy will hold the tablet compartment lid shut - it'll stop them coming out properly.
After a while the water movement will move the obstruction and the tablet will come out, but it'll only be dissolved for a bit of the wash and the dishes won't be cleaned properly.
Dec 18, 2007 | Magic Chef CDB6100 Built-in Dishwasher
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Dryers Logo
51 people viewed this question
Top Dryers Experts
