Can you display your av input, in this case my cctv in the pip window whilst the screen is being used as a pc monitor, if so, how do you select which input or channel you want in the pip window? many thanks
    Sergeant:
    Champion:
  • 319 Answers
If you want to view your CCTV in PIP window of PC monitor, make sure your PC has PIP capabilty. Check operations manual for this feature
Posted on Apr 21, 2008
No signal when i used vga monitor connector to pc, no problem in dvi
Michael,
I have both ASUS and LG monitors with multiple input choices. On both, when the monitor is turned on, it remembers the last input source. Both monitors (and presumably yours, as well) have an INPUT selection in their SETUP MENU.
So, I'm suggesting you search your monitor for an INPUT selection option, then choose "VGA" rather than DVI / HDMI / AV / COMPONENT / CABLE / ANTENNA, etc.
Hope this helps.
Sep 02, 2014 | Acer Computers & Internet
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
HOW TO ENABLE PIP ON SAMSUNG 530?
hello noni calipes,
To enable PIP on Samsung series 5 its easy.
But you should know Samsung spec first (read the manual book).
PIP can be enabled if :
1. Input must be higher or equal to componen. (Componen, PC , HDMI)
2. PIP only displayed inputs as the primary and RF and AV (SD) as secondary.
3. PIP on Samsung 530 can not swapped.
4. The higher inputs will displayed as primary.
If any questions , call samsung cervice center or you can read manual book.
I hope help you.
Thanks.
Mar 30, 2011 | Samsung Televison & Video
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I am using this monitor with our CCTV system, it is not currently displaying the video. As I cycle through the inputs the video image will display for about 3 seconds before disappearing.
Hello there,
ok so if i understand this problem correctly you have a Monitor connected to a DVR for a CCTV System, when cycling through the inputs on the Monitor you find the correct input for the CCTV system but the monitor only stays on this input for a few seconds .
sounds like the input is going out or the Monitor is programed to stay on a single Input, I would try both move the CCTV System to another Input on the Monitor and if that fails see if the Monitor has any Pr-Set settings then you can Default .
if you need any Help with the Default let me know and i hope this information was helpful don't forget to Rate.
Jan 27, 2011 | Bosch MON152CL (Black) 15 inch LCD Monitor
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
I have a hp 2335 monitor. Every so often the pip displays in the top-right corner of my screen. Pressing the pip button sometimes removes it, but I want it to stop appearing altogether. How do I do this?
OK, I think I've got this fixed for mine now. Go to the OSD menu, Video Input Controls, PiP Control, PiP Size, and select PiP OFF. I think I must have been getting noise on the composite video input that was causing the PiP field to display sometimes.
Apr 26, 2010 | Computers & Internet
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Jun 24, 2007 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
