Question about Insignia 32" 720p Flat-Panel LCD HDTV
Insignia 37" Flat Screen Blue Power Light On No Picture No Video
I am currently trying to repair an Insignia TV that is not under warranty. The history of the problem is rather short. I was watching TV when suddenly there was no picture and no sound. The blue power light remained on.
Here is what I have done: I cycled power several times with varying time delays up to a few hours. The blue power light will illuminate but there is no picture and no sound. I attempted to change the input, but the MENU screen does not appear either. I opened up the back of the TV since I have nothing to lose other than breaking something that is already broken and tried to find what was wrong. I could not find any schematics online to guide me.
Here is my question: I am wanting to replace the main board (the larger of the two boards with all the video inputs on it). Here is why, I traced the wires from the speakers and what appears to be the video card at the top of the set and they all lead to this main board. All the video inputs such as the HDMI and PC jacks all lead to a main box. Before I drop money on this, is it sound logic to conclude that this main board is the only thing in common between the sound and picture and should be replaced? The system is getting power as evidence by the blue power light.
  • 11,361 Answers
How to repair an insignia 37" led tv
The first thing I would try is to disconnect the tv from the power source. Wait five minutes before plugging it back into the wall socket. Turn the tv back on and see if you get a display. Try changing the channel and switching inputs. See if you can get it to display anything at all. You could shine a flashlight at the screen and see if you can make out an image. If you see an image with a flashlight then your backlight is out.
Is your tv less than a year old? If it is less than a year old you are still under the manufacturer's warranty. I would see if Best Buy would honor the manufacturer's warranty in store. If that is not the case they should give you a number to contact Insignia directly.
If your tv is out of warranty, it may be cheaper to replace it. I would do your homework and check the price of a repair vs the price of a new tv.
Jul 29, 2016 | Insignia Televison & Video
No power...insignia 37" flat screen wont turn on?
this problem can be fixed by opening the back cover of the television to check for blown fuses, and if found replace with the same current rating and if otherwise the power board supply is bad try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
Insignia 37 in lcd, trun on light gose blue
It is the main board failure, because Insignia TV has no error blink design.
May 10, 2010 | Televison & Video
My tv power light comes on but the screen will not come on.
power light on blue , screen dose nothing ,trun off red light blinks
Apr 08, 2010 | Insignia 37" LCD Flat-Panel HDTV
I have an insignia lcd tv and the screen turned white. I still hear audio but the screen is white with a faint picture.
Your TV requires repairs. Service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada. If your product is within the factory warranty period, your repairs should be completed at no expense.
Feb 28, 2010 | Insignia 37" LCD Flat-Panel HDTV
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
LT 30 HV Olevia Syntax No picture - blue flash
Ur video converter board is dead.
Need to be change.
Aug 15, 2009 | Insignia 37" LCD Flat-Panel HDTV
When i turn on tv screen is bright white instead of blue!!!
This is a problem that should be taken in for service as there could be many problems causing the problem. The power supply could not be supplying voltage to run the video card or you could have a failure in the video card itself. Try calling this number for Insignia Customer service help. 1-877-467-4289. Hope this helps you with your problem.
May 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
I have a 37 inch Insignia flat screen tv. This morning we were watching tv and all of a sudden the tv went black. We still could hear the movie playing but no visual. We turned the tv off and on and all...
This unit needs to be tested in a service center because it has problems with the operation of the video card. This could be caused by a loss of voltage supplying the video card from the power supply card. Or a failure on the video card itself. You can purchase parts for unit from Best Buy Parts at !-888-237-8289 and get customer service at 1-877-467-8289. You should get an estimate from the service center, That should tell you which parts are bad and then you can proceed from there. If the prices seem too high for parts and labor from the service center, try buying the parts yourself and have them install them for you. You should try to check the prices on the parts , just to make sure you are getting a fair deal.You can do this by getting the part numbers, you should ask the service center to provide the part numbers needed if they need to replace the power supply board or video board and with your model number of television check out the prices and availability at the Best Buy Parts website.Of course if the television is still under warranty send it in for warranty service. Hope this helps you with your problem.
Apr 26, 2009 | Insignia 37" LCD Flat-Panel HDTV
Insignia NS-LCD37-09 turns on but no image
If your TV is less then a year old, still under manufacturers warranty. If not under warranty the defective parts could be the power supply or the back light inverter board. Both boards can be replace easily.
The way to know if you have a defective backlight inverter is by shinning a light from a flash light near the screen with the TV on and check in a 45 degrees angle if you have a dark video in the background, if the video is present then you have a backlight board failure. If no video, then is a power supply failure.
I have both boards if you want to buy them.
Let me know if you require further assistance.
Jan 08, 2009 | Televison & Video
Insignia 32" 720p Flat-Panel LCD HDTV Logo
425 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
