Question about Beko 324250WN 28" TV
TV colors are wrong
My TV screen now only shows green, purple and blue colors in a circular shape on the screen, i think somthing went wrong with the inner Tube?
How do i fix this issue?
Thanks for all the help.
  • 36 Answers
Hi,your problem is not with the tube but with the degausing circuit,a very easy repair which should not cost to much,a small componant called a possister in the primary power supply,a 5 min job for a competant tv engineer
Posted on Apr 21, 2008
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
Monitor With Green Tint
Are you using rgb cables? if so the cables might be loose or in the wrong color rca. Hope this helps
Aug 09, 2009 | Toshiba 57HC85 57" Television
Green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Have a model 43A10 toshiba tv, has a purple color at very bottom of screen about inch tall. When i go into the menu, looks like writing is not lined up on the lower options of the menu. and partly up...
you either have a color purity problem or a convergence problem. purity can be effected by electro magnets in power supplys of audio amps and subwoofers too close to the tv
Convergence is the ability of the red green blue to drop on top of each other. can usally be adjusted via remote control. Please claify and repost.
Apr 03, 2009 | Toshiba 43A10 43" Rear Projection...
Color problems
green overpowering makes me think you have a crt problem. or even a bad blue or red crt.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Color problem
Replace D805 (?) Thermistor for permanent fix, manually
degauss with coil is temporary........T.
Oct 29, 2007 | Panasonic CT-36SF37 36" TV
Beko 324250WN 28" TV Logo
257 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
