Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Change door seal in westinghouse SB 907
Do I have to dismantle the door to fit a new bottom seal?
  • Westinghouse Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on Jul 19, 2010
The freezer door at the bottom of my Westinghouse French Door fridge won't shut properly on one side. It is 4 years old, it seals at the bottom but not the top.
Probably slipped off of track. Empty until light enough to completely remove drawer. Make sure guides are intact and reinstall properly.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Feb 20, 2017 | Westinghouse Refrigerators
The Door leaks at the bottom seal, new seal is fitted, can the door be adjusted
The seal at the bottom of the door is PASSIVE (not actually sealed). If you are leaking there, look for correct type and quantity of soap, and be sure the machine is LEVEL.
Jul 01, 2011 | Electrolux Dishwashers
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Indesit D4000 Dishwasher seal
you will find the door seal has some shape to it at the two corners,if not fit the seal from one of the bottom corners first with about 3-5millimeters passed the frame that the seal fits into,then push in all the way round to the other end,the seal has a flap type shape on it which should be fitted with the open end apearance of the seal (flap)pointing towards the door
May 30, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwashers Logo
591 people viewed this question
Top Westinghouse Dishwashers Experts
Fred Sops
Terry
Marvin
Marvin
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
