Canon powershot sd750 memory card files were uploaded to laptop. When the memory card was placed back in the camera an error shows stating incompatible jpeg. How can I view files on camera again?
Try to retrieve the files from the memory into your computer, if you can't see the pictures after they are moved, they might have been corrupted while you were using the camera.
In theory, you might have placed the camera near a strong magnetic field, like a speaker. This could explain the files being corrupted if that's the problem you have.
turn off the camera, take out the memory card and then look at its sides. You'll see a lock slide that you can adjust to unlock the card. place it back and then turn on the camera. Feel free to rate and comment on how useful the info is
Remove the memory card from the camera. Note that there is a small slide switch on one of the long edges of the card. Slide the switch to unlock or lock the card.
I had the same problem. My problem was that there were more than 1,000 images stored on the memory card. Once I deleted some of the images from the camera memory card, I was able to download pictures again.
Bear in mind that you don't need to use Canon software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
