Question about Nikon Coolpix S210 Digital Camera
When i turn my camera on the lens has issues and then a screen comes on saying "lens error"
    President:
  • 1,382 Answers
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jul 17, 2010
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
I turn my dmc-fh27 camera and the lens won't come out. it is trying to move but it will not budge and the screen says "System Error (Zoom)".
Warning: This is only a last resort if you no longer have a warranty.
I used a variety of different methods, but here's what worked for my camera. Apparently the lens was just off the track.
1. Turn on the camera, and smack the back against the palm of your hand to get the lens to come out.
2.Hold the lens out until the "error screen" comes up.
3. Take the camera with the lens facing towards you, and use your thumbs to push on the lens.
4. Push firmly until the lens "clicks".
5. Turn off camera, then on again.
6. Hopefully cry tears of joy that you fixed it.
Jun 12, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
Thanks.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
My digicam lens keeps on moving... coming in and coming out and the screen says "ACCES"
The ACCESS error message displays when there is an internal malfunction or a malfunction with the Lens. This may also appear when accessing the Memory Stick for reading or writing the data. If the Lens is moving in and out then follow the steps mentioned below. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Jan 19, 2011 | Sony CyberShot DSCS750 Digital Camera
My camera says lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 17, 2009 | Nikon Coolpix S210 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
The lens will not retract when the camera is turned off. the screen says focus error when the camera is turned on. is there a way to fix this problem?
I was able to lightly tap the lens in with the tip of my finger while turning the camera off. Then I applied a little pressure on the lens while turning it back on. I guess I was thinking that I would make the lens work a little harder to come out and tighten whatever may have slipped or something. Anyway, after dropping it on carpet and tapping the lens, then the pressure.... It works. Hope this helps..
May 09, 2009 | Fuji FinePix A500 Digital Camera
Lens
Call 800 730 6597 and we will replace it if it is still in warranty
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Oct 28, 2008 | GE A830 Digital Camera
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
130 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
