Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Icon of my passport does not appear
Ihave my passport inserted in the usb slot, it is recognize by the computer but the icon does not appear. what do you think shall i do?
  • 41 Answers
What icon do you mean? im using also this kind of external storage.. try to resart your pc or reinstall the smartware.
Posted on Jul 18, 2010
My USB giving message of Insert a Disk into drive !
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
Apr 16, 2010 | Electronics - Others
No instructions on how to use MY PASSPORT 500GB portable hard drive recieved as xmas present.nothing in box exept drive
Congratulation on your Passport.
Use the USB cable that came with it to connect it to the computer.
The computer should recognize it.
Open the file explorer to see the My computer. The drive should appear there, along with the C: drive.
Click on the Passport icon and look for an executable file WD-Synch or something similar. Click the executable and you will set it up.
If you do not want to use the synchronizing and other software that came with it, just use the drive as storage space.
If the drive seems not to be working, and if it came with a power adapter, then it should be plugged in. Usually the USB port of the computer supplies the necessary power, but sometimes that is not enough and certain drives have a power adapter.
Before removing the drive you should use the Safely Remove Hardware program.
Dec 25, 2009 | Electronics - Others
WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Jun 24, 2009 | Western Digital Passport WDXML800UE...
Sansa icon will not appear in source window
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jun 22, 2009 | SanDisk Sansa e250 MP3 Player
Un recognized drive
what you should do is search for a driver for it so put the name of the usb then driver in a search engine and download and install a driver this should make the computer able to recognise the usb's software
Apr 04, 2009 | Western Digital WD Passport 250GB Portable...
Passport 2068 only accepts WiFi card in startup.
When your card is inserted and after few minutes to activate Sw, right click on wireless card icon and try repair.
It's normally working for me 3 out of 5.
Sometime I have to retry.
Feb 17, 2009 | Ashton Digital Passport 2068 Notebook
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
Sep 28, 2005 | Apple iPod nano
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
331 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
