I have a Maytag lat8714aae top load washer that I need to change the belts on. How do you open it up to gain access to the belts. Or would it just be easier to turn it over?
    Champion:
  • 274 Answers
Well to excess to it ,you can tilt the washer on its side,there is no belt to it.from the motor they have a direct transmission.what is the problem with the washer?
Posted on Jul 17, 2010
I have a maytag top load washer the washer will drain but will not spin
Maytag washers have two belts one for turning the pump and the other for making it spin. Sounds like the belt for the spin needs to be replaced. It is something that you can do. Maytag washer belts are quite easy to change. Hope this helpedd. Thank you for using Fix ya.
Jun 26, 2011 | Maytag Washing Machines
Our maytag neptune front load wash machine squeaks right before it changes directions in the wash cycle. what's wrong with it?
Your belt is stretched...........
There is only one belt, you have to access it from the back, removing the center panel. These belts are really tight when you install the new one you have to rotate it on, and you may thing the belt is too small, but it requires force. Some models you can move motor by loosening the lock bolt to gain some play, usually not much if any.
Remember to unplug before service, and watch for sharp metal edges....
Feb 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
I NEED INTO GET INTO THE TOP OF THE WASHER TO REPLACE THE OPEN LID KILL SWITCH
You should be able to remove / open the top control panel (rear top) screws and tip it out forward to gain access to the lid switch. Be careful of the small air line that goes to the pressure switch. If that comes unhooked your machine will over fill.
Jan 12, 2010 | Maytag Atlantis MAV6451 Top Load Washer
How di change the belt on a 2000 maytag top load washer?
HI. you may have a defective idler pulley. excessive bearing clearance can cause the belt to slip off at times. A worn belt will slip off as well. i suggest gaining access to the belt to inspect for damage. you can start by pressing in the middle of the longest straight run. It should deflect no more that one inch. also inspect the belt for cracks, frayed edges or other signs of excessive wear. if any damage or excessive looseness is found, replace asap. It could also be stretched.
((You can check the pulley by removing the belt and physically rotating the pulley, if the pulley has excessive wobbling or shifting, replace it))
Sep 03, 2009 | Zanussi ZWF1430W Front Load Washer
Little black tube fell off rom under washer what is it and how do i fix it i have a maytag top loading washer
This is from where your water is pumped out down the drain after the was and rinse cycles. It is attached with a hose clamp. Gain access to the attachment coupling, refit, and tighten the clamp.
Jul 26, 2009 | Maytag SAV5710 Top Load Washer
Maytag Stacked washer it fills up but it doesnt cycle
Hello, sounds like you have a faulty lid switch . The lid switch is located behind the tub in the right rear, the front panel and the washer top panel have to be removed to gain access to the switch assembly. good luck
Dec 22, 2008 | Maytag LSE7806A Top Load Stacked...
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
