Question about Whirlpool GEW9250 Electric Dryer
Whirlpool duet electronic gas dryer noy heating up
I have a 6 years old whirlpool duet gas electronic dryer that stopped heating up for the last two days. Everything else is working, the drum is rotating the way it should. The lint trap is clean and the exhaust vent has free flow of air. Please advise, thank you
    Champion:
  • 274 Answers
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Posted on Jul 17, 2010
6 year old dryer will not heat. Gas line & supply
Use this video to replace your gas ignitor.
http://www.youtube.com/user/RepairClinic#p/search/10/NVvI2kbOA-g
Aug 19, 2011 | Whirlpool WGD5320SQ Gas Dryer
My dryer wont heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Dryer - Working but no heat
i need help fixing my 5 year old dryer. whirlpool duet model GEW9200LW1. I have replaced the thermistor. I tested (with an ohm meter) the heating coil, thermal fuse, high limit thermostat, & heating element and they were all fine. I replaced the electronic control assembly and the user interface. THE DRYER STILL WONT HEAT.
Then it occurred to me that the sensor may not allow the dryer to heat if its not sensing wet. Could this be true? Have I been trouble shooting this wrong?
Help me.
Dec 16, 2007 | Whirlpool GEW9250 Electric Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
269 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
