Question about Sunbeam 2545 Mixer
I have a Sunbeam Model A24 Mixmaster which will only operate at fast speed , I.E. the motor speed control no longer functions. Is it the capacitor? I have checked the points and they appear good.
G'day tandjcox842, did you get an answer to your question? If not, and you'd like to offload your mixmaster, I may be intersted. I've got one that works well but is missing parts. Regardz, Perry.
Posted on Feb 08, 2011
How do I tighten the speed control dial on a vintage Sunbeam Mixmaster PowerPlus?
There is a cover plate over the screw that you need to tighten. This cover plate is held in place by two spring latches, 180 degrees apart. Use a small flat-tip screwdriver to depress first one latch, then the other. Don't use too much force - the latches are plastic and will break if treated roughly.
Jan 27, 2015 | Sunbeam Food Mixers
Mixmaster motor won't spin. Leads from circuit board to motor read 119 volts at the motor. voltage does not vary when speed knob is rotated but does turn off & on. 275 W sunbeam mixmaster, white...
so far I determined the thermal fuse had blown. I jumped around it but can get replacement. Now the motor runs full speed when turned on. I suspect the pot turned by the speed knob is bad. Having trouble locating a replacement circuit board.
Jan 19, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam Mixmaster will only operatte on high speed.
Are you proficient in electronic component repair? If not, then leave this sort of repair to a service professional.
You can find parts here:
Sunbeam Mixer Parts
Jan 28, 2018 | KitchenAid K45SS Classic Stand Mixer
Sunbeam Mixmaster is smoking from the motor.
I wouldn't turn it on again , if the switch is smoking then for all practical purpose;s the brush;s are nearly shot as well. I would look around the good will thrift shops or a Salvation Army Store you ;ll find a nice one there for less than a repair bill. You never know what you will find there. Have fun hunting.. DFD please rate me. Tku
Apr 11, 2009 | Sunbeam 200 Watts 2372 MixMaster Series...
SUNBEAM MIXMASTER A24 - ONE OF THE CLIP IN CAPACITORS IS DEAD
I also have an A24 Mixmaster. The part you threw away was a wire wound resister. My problem is that the 0.05 MFD 190-250 VAC capacitor has gone short circuit. I am trying to locate a replacement, either new or secondhand.
Apr 10, 2009 | Sunbeam Food Mixers
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
My sunbeam mixmaster is stuck on one speed - fast!
it will be the motor suppression capacitor fitted accross the speed control. When they fail and go short circuit, sunbeams run at their highest speed. Remove it and replace and all will be well.
Feb 09, 2008 | Food Mixers
Sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Nov 25, 2007 | Sunbeam 2485 MixMaster Series Hand Mixer
Food Mixers Logo
418 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
