Question about Pass & Seymour #690IGCC6 15A Ivory DPLX Switches
Our switch for the ceiling fan burned out today. Instead of getting the same type of switch (rotary knob with push on/off) I bought a Pass & Seymour combination toggle switch (dual on/off toggle switches). My goal is to have one switch on the fan and the other for the light. When we wired it up 1 switch operates both the fan and light and is also tied into out exhaust hood over the stove. The other switch is tied into the downstairs bathroom. Inside the switch housing there are 3 white wires tied off together not being used. On the back of the old switch there was the ground wire and 3 black wires: 1 black wire (from house) was connected to 1 black wire on switch and the other 2 black wires (from house) were connected to 1 other black wire on the switch. Any help would be greatly appreciated. Thanks
  • Pass & Seymour Master
  • 17,956 Answers
The wire to the ceiling fan are meant to send voltage to the fixture only and are not usually wired to control both the light and the fan independently. In order to do that, you may have to pull another set of wires to the switch box and then connect them to the light circuit in the box where the fan is. In regards to the other wiring that you mentioned, it makes no sense that the wires go to the stove fan and the bathroom fan unless those wires are source wires that carry the incoming voltage.
Posted on Mar 17, 2017
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I have a 1-pole toggle
1st thing you need to do is wire nut the white wires together. Then you need to wire nut the ground wires together. Once that is done then you can push them into the box.
Now you will need to find the hot wire that is the one that supplies the power to the box. To do this you need a tester like on the link below.
Once you have found the hot wire you will need to attach it to the switch the side that has the gold screws.
The other two wires takes the power to the fan and light. You will need to find the one that runs the light and put it on the top screw on the other side of the switch. The last wire you will put on the bottom screw on the same side of the switch that you put the light wire.
http://www.homedepot.com/buy/electrical/electrical-tools-accessories/klein-tools/non-contact-voltage-tester-93406.html
Good Luck and please accept the answer
Posted on Oct 06, 2010
SOURCE: I am using a Pass & Seymour illuminated three
I answer questions for free
I work with timers and electrical devices.
If I understand correctly you replaced a 3-way switch.
The new switch has 3 screws (plus green ground screw)
You put the Hot wire on the dark screw correctly.
You attached the two travelers to the brass-colored screws.
The two travelers are red and white.
You connected the ground wire to the green screw.
The ground wire is not supposed to be connected to with the white wire, and I doubt it is because that would trip the breaker.
The lights are working correctly.
If you followed the formula above to the letter, then the lighted switch should light up.
My best guess at this point is that the lighted switch is defective.
The Pass and Seymour webpage does not have manuals to look at like Leviton and Lutron products.
As a result I can't pour over a manual and put a magnifying glass on the wiring and wording to see if there is something we've missed.
But it's just not that complicated ... the light switch should light up.
At this point, I suggest you re-read the instructions (just in case?) and then swap the switch for another one ... or get different brand.
Posted on Nov 04, 2010
SOURCE: I have the 691pass&seymour
Thank you for the clear description of your P&S device.
You need to test your wires.
We are looking for the Hot, Neutral and Load wires.
Your old switch has two wires.
One of these wires is the Hot (I suspect 100% that the wire that comes from the other wires that are twisted together is the Hot)
The other is Load
Separate the old switch wires and turn on power.
Use ordinary tester.
Test each wire to metal box and see if the box is grounded.
Tester will light up on Hot wire.
You can also test each of the old switch wires to the other wires in the box.
1) Hot: Once you determine the Hot wire, this wire will connect to the P&S device:
Hot connects to the brass screws on right side, just as you said ... and these screws are on opposite side from silver screw.
2) Load: The wire to Load connects to brass screw on top left, which is on same side of device as silver screw. This screw sits opposite the P&S switch.
The last wire is the Neutral.
Test your Hot wire to all other wires in the box.
When the tester lights up, that is the Neutral
3) Neutral connects to silver screw which will complete the circuit to the P&S receptacle.
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Posted on Nov 09, 2010
SOURCE: I'm want to install a
More information is needed.
Unknown what wiring device was there before, and which wires were connected to which screw terminals.
Wire color is not as important as knowing what wire is for.
If both white wires were connected together before, then they need to be put back same way.
Separate wires. Turn on power. Test each wire to bare ground. Tester lights up on Hot wire. The Hot wire is usually black.
In back of box are white wires twisted together and covered with wire nuts. These are the neutrals.
Test black hot wire to neutrals and tester will light up. If box does not have neutrals, then device cannot be installed to code.
Open following link for illustration of wiring:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Posted on Aug 01, 2011
I CAN'T FIND A SWITCH FOR MY FAN IT HAS 4 WIRES GOING TO THE OLD SWITCH
Ceiling fan switch is hard to find the correct one. I've wired direct to high speed and add a remote control or use a rotary contact light switch and omit one of the speeds.
May 23, 2018 | Rotary Electrical Supplies
My 3-speed ceiling fan is connected to an on/off wall switch that turns it on and off but the pull chain does not control the speeds. It is stuck on slow speed. I tried replacing the pull chain switch in...
Guess what? A standard dimmer switch will not properly operate a fan motor. In fact, it’s most likely going to damage the fan motor and it could even potentially cause a fire. I’ll admit I even went out and bought a dimmer switch and I sat down to just “make sure” I was doing the right thing when I figured this out.
Standard dimmer switches are designed for the wattage of lights. Fan controls are designed for the amperage of the fan motor. So if you want to control the speed of a ceiling fan make sure you buy a fan speed control that specifically says it works for fans. Fan controls come in quite a few styles. The most common type has been around for quite some time and that is the rotary or dial type. The next most common fan control I found was the toggle that has three pre-set speeds (slow, medium and fast). You can also get a fan control that has a slider control along with a toggle switch.
dimmer+switch.jpgThe type that I want to install is a toggle switch with a small slider switch next to it. I have a feeling I’ll have to order one of these but I’ll check with my electrician tomorrow to find out the scoop. The bottom line is you can’t use a standard dimmer switch to control a ceiling fan. You have to get a fan speed control switch that is specifically designed to operate fan motors.
the short wire leads coming from the switch should be attached to other wires with small wire nuts. Just unscrew the wire nuts, unscrew the finial type cap that holds the switch in place, remove the switch and take it to the store. If your lights are strictly "ON"-"OFF" there should be just two wires from the switch. If your lights are controlled - "One" "TWO" or "THREE" at a time the switch will probably have three wires coming from it.
http://www.ceiling-fans-n-more.com/
Thanks for contacting Fixya.
Jun 14, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Where can I purchase a fan switch for weather works CH-V18 ?
How much do you know about wiring? I cannot locate a manual for this fan. It is a Chinese made 3 speed fan with a sparate speed control box. From pictures, the speed switch appears to be a rotary style switch which can be purchased from local hardware stores or on-line (Digikey). Pull the old switch out and search for a replacement. The import criteria is: voltage rating, amp rating, number of positions (speeds), knob shaft diameter and type.
May 11, 2014 | WeatherWorks CH-V18 Floor / Box Fan
Hunter ceiling fan motor is hot
I put my ceeling fan up today but I have just noticed the motor is reslly hot ,,,, HELPPPPP
Jul 01, 2012 | Hunter (25417) Ceiling Fan
I REMOVED THE AC FAN SWITCH FOR THE THE FAN AND WHEN I PUT IT BACK ON IT DOES NOT TURN ON ANY MORE. HOW DO I RE-INSTALL THIS TO WORK AND TURN ON FAN FOR AC AND HEATER?
Fan switch ? Blower fan or engine cooling fan ??...I presume you mean the blower fan speed control switch.
On top of the battery under the hood, is a set of Green 30Amp fuses. These burn out the holder and a/c no longer works.
If so, by pass fuse with a replacement/repair '' in line fuse'' of 30 Amps from you local parts store.
Other reason fan not working is failed fan resistor under glove box near fan housing....although this is usually low speeds not working by HI does.
If you have the non electronic a/c system, the a/c rotary switch in the panel burns out often.
Jan 24, 2011 | 2004 Volkswagen Beetle
I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click on...you can turn the knob and increase or decrease the fan speed. You can click on both...
Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
Jun 18, 2010 | Hunter Ceiling Fan Control Switch
Three way switch does not work properly
Very interesting problem! But easy to fix. It's not a defective switch, just a minor wiring error, which would be very hard to solve via back and forth text. So, instead of trying to figure out exactly which wires and terminals to swap at the new switch, it would be much easier to simply swap the light and fan wires at the ceiling fixture, I hope this is helpful. Good luck, Al Kupchella
May 16, 2010 | Pass & Seymour / Legrand 1595-2SWT...
Pass & Seymour #690IGCC6 15A Ivory DPLX Switches Logo
49 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
Mike
somegooey
Level 1 Expert
Gil Shultz
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
