LG Intello washer won't initiate cycle. The machine will light up as I select the cleaning option and then push the start button. But the machine does nothing for 1 minute and then all lights begin flashing. The machine makes no noises and nothing appears to engage.
  • 101 Answers
Check the door switch, the machine doesn't see the door closed that is why it wouldn't go into the wash cycle.
Posted on Apr 21, 2008
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
How do I clean my washing machine? My clothes and the washer have a mildew odor.
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Aug 18, 2011 | LG WM-2277HW Front Load Washer
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
Water turned off unexpectedly now machine won't spin final cycle and timer stays on 4 min and appears to continually try and drain ( intello 7.5
Unplug unit for 5 minutes to reset control board. If problem still persists, you will need to call a technician to service it.
Jun 15, 2011 | LG WM-2277HW Front Load Washer
LG intello front load washing machine not starting Select cycle as always and press start nothing then it beeps and flashes all lights
check filter and drain pomp...if ok check motor brushes .. bsc appliances 07779933829 postal service too.
Feb 26, 2011 | Washing Machines
LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
Jan 02, 2010 | LG WM2455 Front Load Washer
It showing cl on the screen
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for a 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds.
If this doesn't work then try pressing "options & select" till the light goes off.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | LG Washing Machines
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Can't make tub clean setting work
Thanks to a couple of previous responders, 6 months of frustration has now ended - I can now run the Tub Clean on my LG Steam Washer! I first want to say that it is important not to get excited and start pushing buttons randomly, as I think I had been doing for all these months when I couldn't get Tub Clean to work by pushing the button in for 3 seconds. Just do the following, which combines and expands on a couple of previous responses:
1. I had to deactivate the Spin Sense, and if your Spin Sense is ON, you will have to do this too. (It is ON if the spin speed light flashes while any of the wash cycles is in progress. If spin speed button does not flash while a wash cycle is in progress, the Spin Sense is already off.) So how to deactivate Spin Sense? Select Speed Wash, and start the cycle. Let it run for about 20 seconds and THEN push and HOLD IN in the Spin Sense option button for 3 seconds. The blinking spin speed button will stop blinking and you will then know that the Spin Sense is OFF.
2. Once Spin Sense is off: Start with your machine turned off. Then push the power button on and select the RINSE AND SPIN option button. Then START the Rinse and Spin cycle. Let it run for about 5 seconds and then PUSH IN AND HOLD THE TUB CLEAN OPTION BUTTON FOR 3 SECONDS. You will then see the little LED light panel show something that looks like tcl. And you are there! Just leave it alone .... the LED will change to one hour and 25 minutes. And it will clean your machine just great.
3. Don't forget to put your bleach in the detergent cup before you start all of this.
I want to thank the two responders above who gave me the essential features for this fix. I forgot to make a note of their names before I started this response, but you can see who they are. I am so excited. Now EVERYTHING works on my LG Steam Washing Machine. I love this machine. It is a miracle of cleaning, especially since I own 4 large breed dogs and am washing and sanitizing large hairy and smelly bedding each and every day. And I no longer have to iron anything - I just use the steam cycle to unwrinkle our clothes. Best washer I have ever owned (and I have owned another major brand of large capacity front loading washer before - no comparison).
May 15, 2008 | LG WM2688H Front Load Washer
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
