Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
I have Samsung dlp 50 Inch tv (hl P5085W) Not working Changed the New Lamp turned On getting Sound (like a Air conditioner Compressor) for a Minute then getting the Triangle signal with Light Symbol
electronick
  • 505 Answers
SOURCE: Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
Posted on Jan 08, 2009
  • 1039 Answers
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
Posted on May 02, 2009
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
SAMUEL011
  • 39 Answers
SOURCE: my samsung hl-p5085w is humming all the time and
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Regars
Posted on Jan 07, 2010
welcomejee
  • 10594 Answers
SOURCE: Samsung HLP5085W DLP - lamp
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Posted on Jul 04, 2010
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
I try to get tv 50" Samsung HL-P5085W i want to know if this kind of tv works good
Yes. This is a good set. Picture is good. But keep in mind that Samsung no longer makes this set and stopped making DLP tv"s. Parts are dwindling.
Apr 09, 2010 | Samsung HLP5085W 50" Rear Projection...
Samsung 50 inch tv blew last night burning smell at time not getting any picture just a clicking sound
It sounds like either the lamp has blown or the ballast for the lamp has blown. You can call 1-800-samsung for nearest service center.
Feb 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Mar 12, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
