Question about Intel D845GVSR Motherboard
In the board sata port is avaliable - Intel D845GVSR Motherboard
  • 182 Answers
No SATA port is not available with this motherboard, however there are 2 IDE ports available
Following is te details of he ports:
• Up to six USB 2.0 ports
— Four ports routed to the back panel
— Two ports routed to the USB 2.0 header
• Two IDE interfaces with Ultra DMA-33 and ATA-66/100 support
• One diskette drive interface
• One parallel port
• One serial port
• One VGA port
• PS/2* keyboard and mouse ports
Posted on Jul 17, 2010
How do i unlock my sata port 0 wdc WD5000LPVX -22v0TT0
A sata port does not need to be unlocked. if you are having trouble accessing the hard drive connected to the sata port, there may be issues with what driver is installed. find the driver for your mother board sata ports and re-install it. you can also try connecting it to another computer to ensure the hard drive is not corrupted.
Jul 05, 2015 | Computers & Internet
I need to know where to plug in on motherboard
If its having sata connection you can see sata ports on *********** board using sata cable
1.Pic of sata cable
2.Pic of Sata ports on mother board
You can connect any one of the ports. and you need to go to bios and enable the sata ports if its not done already..
If you have a normal CD Drive you can connect with IDE cable.
See the pics below
Apr 24, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
Where are the SATA ports on the hp compaq dc5000 sff mother board?
To the best of my knowledge and working with HP/Compaq for over 8 years, this model does not have SATA ports on the motherboard unless someone has customized your system with a new board other than that which came as the original board.
C2Solutions
Jan 09, 2010 | HP Compaq Business d530 Small Form Factor...
I cannot get the 2 x 4500Gb SATA drives to show up in the BIOS of a intel s875wp1 board. It is an older board and had the RAID setup in place - I just want the 2 x SATA drives as normal so turned off the...
ATA/IDE has nothing to do with SATA. Ignore.
Try plugging in the drives into the non RAID sata ports on the motherboard. I think when you disable raid you also disable the raid ports. You should have another set of sata ports on the motherboard, probably a different colour.
Nov 26, 2009 | Intel S875WP1-E Server Board Motherboard
Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Mar 30, 2009 | Intel Motherboard
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Sata controller was corrupted. cannot install any sata drives or sata drives was not found on the system.
henx, How do you know that the SATA controller is corrupt?
I see you state that your SATA drives are not beeing found by the system. The SATA controller is defective if your bios does not see a connected SATA drive connected to the SATA port & the SATA power connector is also correct & connected. There is not a fix for your issue. I checked every bios version for your P4S800D-X. No SATA fix through Asus. There is only one way to get your board fixed. You must call Asus tech at 812-282-2787 M-F Eastern time. Please have handy the set of numbers found on a white sticker on the serial port. Asus will need this number. Keep your system together as the tech will want you to do some checks before he will issue you a case number. Keep in mind Asus warrants boards for three years. Asus also can not repair your board's defective SATA controller. They will test it & replace board with another. After receiving a case number you'll have to call CA for a RMA No#. RMA dept, will send you a RMA to your email address along with instructions on how to send the board back to Asus.
Feb 29, 2008 | ASUS P4S800D-X Motherboard
Intel D845GVSR Motherboard Logo
160 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
