Question about Intel Server Board SE7505VB2 Motherboard
I want sata raid this modher board - Intel Server Board SE7505VB2 Motherboard
I got two of them u can get me at my email rdujardin@yahoo.com
Posted on Mar 20, 2009
  • 152 Answers
Www.updrivers.com
Posted on May 25, 2008
How do you turn on the SATA controllers for this board? By this I mean how can you put the SATA connections and their drives into the boot order? I can't see this option in the BIOS only to enable the...
SATA Controllers are always on. you can't disable or enable it.
RAID and SATA are two different subjects and they are not dependent each other.
so if you got a problem with your motherboard explain it clearly.
Jan 12, 2011 | MSI K8N NEO2-Platinum (MS7025) Motherboard
I have an Asus SK8V. It is booting off of a 320gb Maxtor SATA drive set with the the jumpers to 1.5gbps because it will not get recognized by the VIA SATA chipset w/o doing that. It is in the normal SATA...
You need to go to ASUS to get a bios update. Since your board only appears to support SATA 1, it probably has the older bios that tops off at about 380mb. drives. (I don't think that a bios update will give you Sata 2 as that is hardware limited)
Mar 09, 2010 | VIA ASUS SK8V MB, 8T800/ SATA/ RAID/...
I cannot get the 2 x 4500Gb SATA drives to show up in the BIOS of a intel s875wp1 board. It is an older board and had the RAID setup in place - I just want the 2 x SATA drives as normal so turned off the...
ATA/IDE has nothing to do with SATA. Ignore.
Try plugging in the drives into the non RAID sata ports on the motherboard. I think when you disable raid you also disable the raid ports. You should have another set of sata ports on the motherboard, probably a different colour.
Nov 26, 2009 | Intel S875WP1-E Server Board Motherboard
Can't connect SATA Hard Drive to MSI PT8 Neo-V Mother Board
You tell where in the System or in the BIOS. In BIOS on the SATA Mode or RAID Mode while in the System you install RAID Software to recognize and detect any SATA or RAID Hardware.
Sep 29, 2009 | MSI PT8 Neo-V Motherboard
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
Need to boot from SATA drive
If you only have one SATA drive, you do not need to have the RAID setting turned on in CMOS. RAID is only for 2 or more SATA or SCSI drives. Shut that off and try again.
Mar 14, 2009 | Computers & Internet
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
HOW TO CONFIGURE RAID
I needed to see your board & can at this site. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=493&DetailName=Manual&MenuID=1&LanID=0
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Luck!
Please vote......
Jan 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Intel Server Board SE7505VB2 Motherboard Logo
91 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
