Question about Microsoft Windows XP Home Edition
Photoshop 7 Whenever i try to run the setup of photoshop the setup does not starts and also donot show any error message. Simply the busy symbol comes and disappears. Kindly suggest
  • Dharmender Kumar Apr 26, 2008
    I tried it by running photoshop7 from CD. It is working on all systems except one. I am using Windows XP and account as Administrator
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Run setup.exe directly from the CD (or download if it was downloaded). Thanks for rating FixYa!
Posted on Apr 21, 2008
  • 1 more comment
  • Cheryl Whalen Apr 23, 2008
    If this did not work, please let me know what is happening and I will try to help further - I really want to FixYa!
  • Cheryl Whalen Apr 24, 2008
    Hi there. Haven't heard back - did you try to run the setup.exe, with the result being the same as the original message indicated? If so, could it be that you are not using an administrator-level account, and that is causing your PC to ignore the program? Also, just in case you're on Vista (though this is in the XP Home edition section), make sure to try turning off User Account Control (UAC) when running setup, as that can also interfere. Or, as I experienced with another program, UAC was turned off and it would not run without UAC being turned ON!
    Few more suggestions without additional info: (1) Make sure that any antivirus or antispyware programs are NOT running, as this can keep any install either from running or make a mess of it in the end. (2) Also, check Add/Remove Programs to see if it has or has not installed. From my research it appears that it installs silently in a number of cases, and a lot of users have thought it just sat there not doing anything only to find that it did install. (3) Check the running processes and be sure that you know what is running (no malware!). (4) Are you successful in opening the CD to explore (assuming it is to be installed from CD), so that you can see the file? (5) Check the event viewer to see what the result has been when you have attempted to run the setup (maybe more than once?) - others have found at this stage that the program actually did install.
    Still others have found a .dll error and/or an issue with JAVA. If the above didn't pan out, try one of these two sites:
    http://www.adobeforums.com/webx/.3bc431d...
    http://www.adobeforums.com/cgi-bin/webx/...
    If this doesn't solve the problem, it could be a faulty CD or other hardware type issue - hope we reach a FixYa with this - please let me know!
  • Cheryl Whalen Apr 26, 2008
    Hi there, Dharamender. I'm not sure I completely understand. Are you saying that you ran the setup.exe, as I suggested, from the CD and it now works on some PCs. This would indicate that it is being installed on several PCs and it now works on all but one - ? Or are you telling me that you are actually running the program itself from the CD, as opposed to installing it to the PC(s) and running it from the PC(s)?
    Did you take action on any of the other numerous suggestions and documents that I gave you, then, on the one(s) where it is not working? Please let me know - and do you think that I have given you enough assistance to reach a FixYa rating? Thanks - and look forward to hearing back...
I installed photoshop 7.0 on my pc.when i tried to start it the error comes "could complete your request because of missing or invalid personalisation"
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
Jul 02, 2011 | Adobe Photoshop 7.0 for PC
When i installing adobe photoshop cs2 , there is error 1311 so how can i solve this
Your CD might be damaged in someway.
You can try this to solve it.
1. Copy the content from the CD over to you computer.
2. Run the setup you just copied to your computer. (if you have Windows 7 or Windows Vista you will have to run the setup as administrator.)
That should fix your problem.
Mar 07, 2011 | Adobe Photoshop CS2 for PC
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
Photoshop 7.0 installation fails with the error message: "An error occurred during the move data process : -106" Upon install process it makes it to about 1% then gives the following error code....
one problem that could cause this error is lack of administrator rights,
right button click the setup.exe or whatever it called and select run as administrator,
Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
Regards
gewiz.co.uk
Nov 30, 2009 | Computers & Internet
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
When attempting to start Adobe Photoshop Elements 2, I get this message " Could not complete your request because of missing or invalid personalization information." Using a PC running XP home service pack...
OK, loads of different fixes for this, have fun.
These errors are caused when a version of Photoshop CS is already on the computer, such as a beta copy, or if your registration information file does not get written properly or is damaged. If multiple copies of Photoshop are in the Applications folder, or if a beta or tryout version is installed in addition to the regular version, the system and Photoshop may confuse which files to use to verify personalization. This confusion can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder in alphabetical order. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
Do one or more of the following solutions:
Solution 1: Remove and then reinstall Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's splash screen upon opening Photoshop, you may have another version of Photoshop CS on the computer. Empty the trash, remove the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
To remove and then reinstall Photoshop:
2. Delete all Adobe Photoshop CS folder(s) in the Applications folder.
Solution 2: Remove and then reinstall Photoshop in another location.
If you uninstall and reinstall and still get personalization errors, or if you cannot locate an installed copy, uninstall any copies you find, empty the trash, and then remove Photoshop, and then reinstall Photoshop in another location that is alphabetically in front of any other installation.
To remove Photoshop and install it in a new location:
1. Move any personal files from the Adobe Photoshop CS folders on the hard disk to another location.
2. Delete all Adobe Photoshop CS folders in the Applications folder.
4. Create a subfolder in the Applications folder, that is named differently from the default Photoshop install folder (Adobe Photoshop CS), and is is alphabetically in front of the other version of Photoshop, such as \Applications\aaaa\Adobe Photoshop CS.
5. Reinstall Photoshop CS and select the new subfolder (created in Step 4) as the install folder when prompted for the installation location.
I know its a lot, but Adobe is a complicated program:) Source(s): http://kb.adobe.com
Aug 10, 2009 | Adobe Photoshop Elements 2.0
Wacom Intuos3 Tablet driver crash in photoshop
I was having the same problems, it only occurred when i updated the tablet driver to v. 5.2.1-6. So i've downgraded to the one that came with my graphire3 (tablet driver v. 5.2.0) ...hope this helps
Running: OS Win7 PS CS3 Wacom Driver v. 5.2.0 for Graphire3
Nov 18, 2008 | Wacom Intuos3 Graphic Tablet
Installing problem...
Try to see if you can resolve with the steps given here
first link
Second option
Apr 12, 2008 | Adobe Photoshop CS2 for PC
Microsoft Windows XP Home Edition Logo
258 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
