Question about Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set
How do i remove the chuck from a ridgid hammer drill
    Novelist:
  • 178 Answers
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting if this drill has a 2 speed transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Posted on Nov 26, 2010
1/2 hammer drill and the chuck is broke what do I do to get. New drill or fix
Assuming that the drill is still operating, I suggest that you get a replacement chuck, To remove the old chuck, insert the chuck key in the cogs on the left hand side as you hold the drill facing outwards, then using a hammer tap the chuck key firmly so that the chuck will revolve anti clockwise. Replacing the chuck us the reverse of the above procedure.
Apr 05, 2017 | Hammer Drills
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Cant get the bad chuck off my RIDGID 18v cordless hammer drill
The chucks on these drills are put on not only VERY tight but usually with some lok-tite to boost so they don't come off easy. In my shop we usually lock a 1/2" hex driver in the chuck and use a 1/2" impact wrench to knock them loose. It usually takes a few seconds to come loose. Another method is to lock the short end of a 1/2" allen wrench in the chuck so that it sticks straight up with the drill standing up. Then lay the drill on its side with the top at the edge of your bench and the allen wrench sticking over the side of the bench. NOTE: The chuck follows the lefty-loosey, righty-tighty rule, the chuck screw is reverse thread. Have someone firmly hold the drill and then hit the end of the allen wrench until the chuck comes loose. Once you break it free it will spin off easily. You do need to put the new one on with lok-tite and as tight as you possibly can then lok-tite the screw and tighten it as much as you can by hand.
Jan 20, 2012 | Ridgid Drills
I HAVE A DEWALT 511 HAMMER DRILL AND I CAN'T REMOVE THE CHUCK. COULD PLEASE ADVISE ME ON WHAT TO DO.
Open the chuck fully and look inside, there should be a screw there that has to be removed to remove the chuck in view of the fact that it is a reversable drill and the chuck cannot be screwed off like a conventional inudirectional drill.
Jul 09, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
I recently got a RIDGID drill Press DP15000 The previous owner has lost the chuck key and I am having problems re ordering a replacement. Can you use any alternative to open the chuck. Hardware store...
Ridgid is sold exclusively at Home Depot. They should carry replacement chuck keys for it. If not they can order it for you. They also make an universal chuck key, looks like a X and has 4 of the most common sizes on it.
May 31, 2011 | Garden
CHUCK IS BAD. TRIGGER IS BAD
You can find the parts on Ebay and fix it yourself.
Jul 08, 2009 | Ridgid 0.5-inch 18-volt Hammer Drill
Can't remove the chuck on a drill.
There are one-way (non-reversible) and two-way (reversible) drills. Mine is one-way. Methods for chuck removal are different for these two types.
Procedure for one-way (non-reversible) drills:
Drills of this type have no chuck screw, so one have to hold the spindle with a wrench, than to sharply strike the wrench with a hammer to spin it off.
Procedure for two-way (reversible) drills:
Open the chuck up and in the bottom is a screw that holds the chuck on the shaft.The screw turns in a clock wise motion to be removed and then you can top the chuck off the shaft.
May 19, 2009 | Black & Decker Drills
Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Mar 25, 2009 | Makita Drills
Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set Logo
561 people viewed this question
Top Bosch Drills Experts
John Trevino
Paul Carew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
