Question about GPX MW3816 MP3 Player
Use overdrive media (like always and never problems before) and can't transfer I get error 0XC00D2779 because device clock is not set?????
    Problem Solver:
  • 7 Answers
Go to http://letsgohealth20.com/ its got all yuo need to fix it
Posted on Jul 17, 2010
Overdrive Media audio book transfer to Asus TF101 error code 0x80045011
Did you ever get this working? I'm seeing the same error when trying to transfer an audiobook checked out from the Dallas Public Library to my Samsung Galaxy Nexus phone.
Sep 08, 2012 | OverDrive Media Console
Sansa M250 MP3 player and Yahoo Music Service
Have you tried this? Open up Windows Media Player. Go to the options menu, and choose privacy settings. Make sure Set Clock on Devices Automatically is checked. Then hit okay. Close Media Player. Connect your MP3 player to the computer and reopen Media Player. That SHOULD synchronize the clock automatically.
Sep 10, 2007 | SanDisk Sansa m250 MP3 Player
Won't load audiobook because clock is not set
Had the same problem - used this solution from ehow.com at this web address: http://www.ehow.com/how_5180421_troubleshoot-sansa-clip-mp.html Worked and now I'm transferring my book from overdrive - hope it helps. Reset the Clip by holding the On/Off switch in the On position for approximately 20 seconds. Release the switch, then attach it to the USB adapter to charge it. This process can help when the Clip does not appear to be working at all.
Dec 16, 2009 | SanDisk Sansa Clip MP3 Player
I received the following message after downloading an audio book using Overdrive Media Console. Error message: "Please obtain license by transferring this title to device using audiobook...
Hi.
I report a solution from Portable player FAQ, let me know if it works:
1. Delete the title in the Overdrive Media Console program.
2. Then log into the Audiobook site at http://e.hbpl.org and click on My Account, My eItems Checked Out, and click the Download button the website to re-download the book.
3. Transfer the newly downloaded parts to your player.
Oct 27, 2009 | SanDisk Sansa Fuze MP3 Player
Can not transfer wma,wmv
The exact description of that error message is: "The file could not be transferred because the device clock is not set."; NS_E_DRM_LIC_NEEDS_DEVICE_CLOCK_SET
It is related to a DRM license that is on the videos that you are trying to transfer - either the video you are trying to transfer has a DRM license that does not have transfer rights, or does not allow reencoding.
Basically, the video you are trying to convert is copyright-protected, so you will not be able to use it on a GoGear, only because the GoGear's require re-encoding first. Sorry.
The only solution is illegal - you would have to use a DRM-Stripper such as Tunebite to remove the license from the video. I would not recommend it.
-Tha Mp3 Doctor
Feb 28, 2009 | Philips GOGEAR SA6045 MP3 Player
Just in the last month this problem surfaced. I download audio books from my library. I have been doing this for the past year. My MP3 player says synchronize to continue your subscription. My library is...
I had this issue with my e260 and Overdrive Media audiobooks. Here is how I solved the problem:
NOTE: Make sure that your license is valid -or the following will make no difference.
1. Windows Media Player needs to be at least 10 -and it needs a security update to be able to deal with DRM files.
2. The audiobook needs to be opened (played) (even just for 1 sec.) on the computer first to "activate" the license.
3. When transferring from Overdrive Media the Sansa HAS to be set to MTP (Media Transfer Protocol) in the USB settings for the license to transfer to the device allowing it to play.
I hope this helps someone. It took me an entire day of research and trial & error to figure it out.
Feb 01, 2009 | SanDisk Sansa e200 MP3 Player
Using Overdrive Media Console to transfer audio books I had downloaded from the public library to my Sansa 200 I get an error message 0XC00D2772. Everything had worked fine for 3 months prior to this...
FiXED!
I fixed it on my e260. The solution: Drag and drop the mp3 file directly into your media player, skip the overdrive 'wizzard', you need to find the folder where the media is stored.
May 22, 2008 | Audio Players & Recorders
Cannot transfer Tracks
To solve the internal clock problem you can try to format the device using windows media player and if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 24, 2008 | SanDisk Sansa m250 MP3 Player
No license to play. sync license from PC
If you are using a subscription service, Rhapsody, or other, you need to sync the device to the service to verify your account and renew your licenses. Generally every 30 days. If this is not the issue then you have used your own cd's and used Windows Media Player to copy your music to your computer. By default Windows Media Player "copy protects" your music. You would need to change the setting in Windows Media Player. Under Tools>Options>Rip Music or Copy Music Tab, the un-check the "copy protect my music" box. Then you will need to re-transfer the cd's to your PC, and re-transfer the music to your device. Make sure you delete all of the previously transferred music, or you will always receive an error. Please add to this question for additional assistance. Best of Luck.
Oct 03, 2007 | Creative Labs ZEN V Plus MP3 Player
GPX MW3816 MP3 Player Logo
629 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
