Question about Intel Motherboard
Gigabyte mb wont recognise dual ram
I put in a new mb Gigabyte GA-M56S-S3. I used the ram i took from the old board which worked perfectly. G-SKILL PC2-6400 4 sticks of 1 gig ddr2.
I put 1 slab in slot 1 another in slot 3 and the bios boots ok.
I put another slab in slot 2 and the last in slot 4 and the bios does not boot no beeps nothing.
I take out 2 and 4 and it boots again. I notice on the screen it says single channel not dual .
Either the mb is bad out of the box or it is a bios setting i cant find to enable dual channell.
I am out of ideas
  • anniets Apr 21, 2008
    There is no dual boot option
    Genius:
  • 2,785 Answers
Please check in bios for dual boot option.plz note for dual - channel configuration your ram should have same frequency and speed.
Posted on Apr 21, 2008
HI, i have the gigabyte MB GA-945P-S3- and i saw in GIGABYTE web site that i can go with C2D E8400 but with overclocking and saw awhile ago that there are another problem with the CPU MP in the bios of it...
Only the Gigabyte GA-945P-S3 revision 3.3 does allow C2D E8400 or C2D E7500.
However the C2D E8400 only by overclocking, which certainly is not recommended.
So the Gigabyte GA-945P-S3 mainboard revision 3.3, should work with the C2D E7500
with BIOS version FFd and FSB setting at 1066 MHz.
Sep 04, 2011 | Gigabyte GA-945P-S3 Motherboard
I need to replace some of the 6.3V 3300ufd caps on the GIGABYTE GA 7DPXDW P DUAL MP SOCKEt motherboard or I need to replace the motherboard. What wattage soldering iron is needed, or where can I buy an...
Normal operating temperature for electronics is 400 deg. Use of silver solder is common. However, MB fixes are rare these days..but given the nature of your board I understand your desire to fix it. Dual boards are not cheap - especially when Tyan had the mrkt tied up. There is a good source for older high end equipment I have used....www.compuvest.com. good luck!
Jun 13, 2011 | AMD GigaByte GA-7DPXDW-P Dual Athlon MP...
Gak8n51 gmf-9 wont recognise high speed usb 2.0 pci card
it might be that the board is to old or the m/board is faulty
Mar 19, 2011 | AMD GIGABYTE GA-K8N51GMF-9 NVIDIA GeForce...
GA M61PME S2P wont recognise 7600gs
You have to select PCI video card in your BIOS setup
Aug 07, 2009 | Gigabyte GA-EG43M-S2H Motherboard, Socket...
Gigabyte GA-945P-S3
1. 4 DDR II DIMM memory slots (supports up to 4GB memory)
2. Supports 1.8V DDR II DIMM
2. Supports dual channel DDR II 667/533/400 DIMM
Jul 17, 2009 | Gigabyte GA-945P-S3 Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Does Gigabyte GA-945P-S3 support 2 gb of ram
Yes, this mothereboard can actually supports up to 4GIG of RAM , so probably the problem lies on the RAM that you have, If you're using 2 or more piece or ram to this motherboard make sure they are the same brand because sometimes you will have problem like this if the memory are not the same brand...this is the link for the complete specs of the motherboard http://www.dealtime.com/xPF-Gigabyte-Gigabyte-GA-945P-S3-945-Core-2-Extreme-Core-2-Duo-1066FSB-LGA775-DDR2-ATX-Motherboard-w-Audio-Gigab
Hope that helps..........
Sep 08, 2008 | Gigabyte GA-945P-S3 Motherboard
Intel Motherboard Logo
128 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
