Question about E-Machines emachines (emachinees) CD-ROM Drive
My dvd/cd rom is not working on my eMachine. When I open My Computer, it does not show an e drive.
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Posted on Jul 18, 2010
2 Suggested Answers
SOURCE: CD Drive not working at all
lg gsa-h12n dvd writer
Posted on Dec 10, 2008
Cdvd rom dont work on emachine, will a usb 2.0 external dvd rom drive work
If it is USB CD_Drive you can plug it in a USB port of the computer. You may have to install drivers, but usually Windows Update can download them from the Internet.
Apr 07, 2013 | E-Machines emachines (emachinees) CD-ROM...
I hv an e machine E725 n the dvd/cd driver is not working what could the problem
Try to Update or Roll Back the driver in Device Manager, DVD/CD-Rom drives. You can find the drivers for the DVD/CD Rom here, select your OS: http://support.emachines.com/em/driver/nb/e725.html If you could explain further what happens when you put in a CD? Is the DVD/CD Rom Icon showing it Computer folder?
Mar 09, 2013 | Computers & Internet
Cd stuck in emachine and there's no pin hole
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
New computer {emachines desktop} cd/dvd drive does not work and does not show up on device listing.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 24, 2011 | E-Machines emachines (emachinees) CD-ROM...
How do I open the tower to insert a c d
Open My Computer and then right click on the CD/DVD drive of your system that are define. For example: "E, or F, or G". Click on eject. or Press on the button CD/DVD-ROM. Mostly it's located in the right sight just below the CD/DVD-ROM "where the CD/DVD can insert". And if this two is not working than take a pin length around 2.5" and push inside the hole it's located in the right sight just below the CD/DVD-ROM. Hope it'll be helpful to you. All the Best!
Oct 07, 2010 | E-Machines eMachines Desktop PC
The dvd drive of my emachine e525 is not working, it shows outdated but when i update it, it says it is already up to date, what must i do to get it to work?
usually when a cd rom... or dvd rom drive is older than 5 years old... it's a good ideal to replace it... sometimes a voltage spike or a voltage surge... can render a cd drive useless... and when you have is the end result... upgrading the bios can aslo make the drive useless.
Apr 05, 2010 | E-Machines emachines (emachinees) CD-ROM...
Emachine W6409. will play cd. will not play dvd.
sounds to me like you have a cd-rom drive and not a cd-r/dvd rom drive? are you sure it is a cd-r/dvd rom drive? If its not it won't play DVD's because CD drives use a different codec than DVD rom drives do. CD-r/dvd drive combos use the same codec though as one.
Jun 06, 2009 | E-Machines emachines (emachinees) CD-ROM...
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
May 28, 2009 | E-Machines eMachines Desktop PC
My computer dont want to play dvd
Well, you need a DVD-ROM not a CD-ROM. If you have a CD-ROM and it's not playing then it's because you need a DVD-ROM and it's not working then I don't know, sorry! From Jake @ Dudey-Dreamz.piczo.com
Feb 23, 2009 | E-Machines emachines (emachinees) CD-ROM...
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Computers & Internet Logo
1,116 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
