Question about AcerPower 1000 (AP1000EA380M) PC Desktop
Dvd rom spins up but no led on power sw and hdd does not spin. There is power on motherboard as heat sinks are getting warm
  • Acer Master
  • 5,660 Answers
The following is in relation to an Acer Power 1000 series desktop computer.
Suggest you check the Power Supply. A weak Voltage power rail can cause these symptoms.
Specifically the 12 Volt rail.
A) Heatsink's are getting warm? Computer case fans spinning?
Computer case fans spin a few times, and stop?
Another indication of a bad Power Supply
But if not, let's go on.
[ The Acer Power 1000 has a bad cooling design. I hope you have cleaned the inside of the computer, as well as the inside of the Power Supply, out on a regular basis as needed.
(Can of compressed air for computers, computer Unplugged from power. If you tip the can of compressed air when using it {Inevitable if you're doing a good job}, some of the propellant will come out.
The propellant freezes the moisture in the outside air, because it is coming out so fast. Therefore time should be allotted after cleaning, to let said moisture dissipate, before plugging the computer back into power )
I also hope you followed Anti-Static precautions, before reaching inside your unplugged from power, computer ]
1) ALL the LED lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts. Those two tiny computer case fans probably use 2 Watts each.
3) A typical Processor uses 51 to 125 Watts.
[Volts times Amp's = Watts ]
The Acer Power 1000 comes with a AMD Athlon 64 X2 processor.
Can use up to 65 Watts. (Depends on which Athlon 64 X2 processor it is)
You don't have enough power to turn the Processor on.
With most of these types of solutions, I suggest checking the 12 Volt power rail, OR using a KNOWN to be good, Compatible power supply for a test unit.
Your Power Supply is unique to your computer. It isn't an ATX style of Power Supply, that you can buy just about anywhere.
It is also Expensive to replace.
[SFX -220 Watt power supply.
SFX = Small Form Factor]
Looking on the internet just know, I have seen prices averaging $68 USD.
My suggestion is to buy a economical multimeter, ($10 to $12), and check the 12 Volt Power rail, first.
Make sure the Power Supply is the problem, before purchasing a replacement.
A) Orange insulated wires are 3.3 Volts. (3 point 3)
B) Red wires are 5 Volts.
C) Yellow wires are 12 Volts.
[All are DC Voltage]
D) ALL Black wires are Ground wires.
All Yellow (12 Volt) wires, lead back to one 12 Volt power rail inside the Power Supply.
Therefore you can test ANY Yellow wire, and be testing the 12 Volt power rail.
I would like you to unplug the 4-pin ATX +12 Volt power cable, from your motherboard. Has two Yellow 12 Volt wires, and two Black ground wires.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Set the multimeter to DC Volts.
If there is more than one scale, set the function knob to the 0 to 50 Volt scale.
Insert the Positive lead (Red) of the multimeter, into the socket of one of the Yellow wires.
Insert the Negative probe lead (Black), into the socket of one of the Black wires.
Looking at the middle photo in the Playtool link, it shows the 4-pin +12 Volt power cable, unplugged.
You are looking at the front of this power cable, and can view the metal sockets inside the four openings.
Computer (Power Supply) plugged into power, press the Power On button.
11 to 13 Volts indicates a good Power Supply.
Less than 11 Volts means it's time to replace.
For questions concerning what I have stated here, please post in a Comment.
[By the way.
Your computer Power Supply, converts your household AC {Alternating Current}, into DC {Direct Current}.
{Either 120 Volts AC (USA), 240 Volts AC, (Europe), or 100 Volts AC, (Japan}
Converts the AC into the DC voltages stated above.
Two C cell flashlight batteries produce 3 Volts DC.
Posted on Jul 17, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
If you can provide the Make
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
When dell optiplex 760 pc turned on the power button keep in amber light. cpu fan was spinning but no video come out rom the screen. Aux power led in motherboard was lighted amber.
rmove the memory from the slot and clean it with a neat cloth and insert and switch on the computer if still not working remove the processor heat sink and clean it with a cloth apply some thin layer of heatsink solvent and fix them tightly also remove the cmos battery from the motherboard and switch on the computer then shutdown the computer and replace camos battery
Dec 30, 2010 | Dell OptiPlex 760 PC Desktop
Asus M4A785-M will not post. I have completely removed motherboard from case, removed all components except CPU (AMD Phenom II X4) and CPU cooling fan. When power supply (which I tested in seperate...
All I read properly .Please remove power supply from HDD and CD /DVD RW. If you face the same problem Open the mother board on a open place and try it again ,because there are some particles witch has made the short sercit in your M. Board.Cgeack all voldage socket plkaced properly,MAY BE CAN SILLY MISTAKE FOR 4 pin socket .
If you face same problem please install in another mother board .Post me please imediate next result.
Dec 12, 2010 | ASUS M4A785M (890552666775) Motherboard
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
Number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Apr 18, 2009 | Intel Motherboard
Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Apr 13, 2009 | Foxconn 760GXK8MB-RS Motherboard
Reset/power/led etc..lead connections
on most motherboard it is possible to read there to set the wires.
hope this helped a little.
May 15, 2008 | Compaq Presario 5000 PC Desktop
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
AcerPower  1000 (AP1000EA380M) PC Desktop Logo
237 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
