Question about Prestige Remote Start
What type of battery that prestige car alarm use
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 19 Answers
Which remote do you have? its usually a gp23a or a slim 12v battery
Posted on Jul 29, 2010
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Posted on Oct 22, 2008
logosc75
  • 625 Answers
SOURCE: how to disable or reset a Prestige car alarm.
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Posted on Oct 29, 2010
reynosaelect
  • 165 Answers
SOURCE: I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
Posted on May 11, 2009
logosc75
  • 625 Answers
SOURCE: I bought my car used
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Posted on Jul 17, 2011
logosc75
  • 625 Answers
SOURCE: i have a prestige alarm system on my car. my car won't start
If this is a wireless ignition system (no metal stem on key) then the issue may be with the bypass module. The unit may need to be reset if the technician cut wires during the installation.
Posted on Jul 21, 2011
My alarm was working fine then one day i just unlocked the car drove then when i tried locking the car with the remote and it didnt work the light that flashes when alarm is on didnt start flashing it...
Sounds like the unit may have seized (common occurence with this unit). Disconnect the positive battery terminal, wait ten seconds, reconnect. If you have a security radio be sure to have the code handy.
May 22, 2011 | Brand New Prestige Aps787n Remote Startcar...
I need to re-program the remotes to my alarm. It is a prestige aps255a. Just to lock and unlock all the doors. To arm and unarm is already programmed.
Huh? Pressing the lock button arms the alarm AND locks the doors. Pressing the unlock button disarms the alarm AND unlocks the doors. If this is not happening either there is an issue with the wiring from the alarm to the car or, with the vehicle's door locks.
Apr 20, 2011 | Audiovox APS255A Car 2 Prestige Platinum...
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
Oct 28, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
Why alarm only works when close to car
Poor range can be caused by a number of things. Has this problem only been occurring recently? If yes, try replacing the battery in the remote transmitter since a weak battery can be a problem. If this is a new install, bring it back to the installer to have them check it. Other possible causes can be improperly positioned antenna, the alarm brain installed too close to an electronic control unit, the alarm brain mounted to a large ground plane or a defective alarm brain.
Oct 22, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
My battery died in my car i got a knew battery now my alarm is keeping it from starting
If the remote fails to disarm the alarm, manually disarm the system by turning the ignition on, then press and release the valet switch. You should hear two chirps, start the vehicle.
Sep 24, 2010 | APS20B Prestige Keyless Remote Alarm
I have a prestige alarm system on my car. my car won't start
there may have been a starter kill relay wired up to this when the alarm was installed, contact the busness that installed it to find out if one was put in and how to bypass it
Feb 15, 2010 | Prestige 2 Button Remote Security System...
How to deactivate a prestige car alarm
remove the fuse in the main harness going in to the alarm unit under the dash, if you have a starter kill feature you may need to bypass this. you will need to make up a jumper wire and place it in pin 30 and 87 on the relay
Feb 07, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
No remote for alarm
until you get a working remote, you should unplug that alarm
Dec 14, 2009 | Prestige Remote Start
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Prestige Remote Start Logo
1,405 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
