Can not turn tv on--light keeps blinking on the switch, but will not come on--no picture
    Sergeant:
    Champion:
  • 319 Answers
Depending on TV, pilot light flashing indicates a problem in circuit. Get pro/tech help
Posted on Apr 21, 2008
4 Suggested Answers
SOURCE: TV on/off light keeps blinking red light/no sound or picture on screen
Here's a solution that I received from an TV expert in another website: "This sounds like a power supply problem. i have seen it several time on your model. i would not keep trying to turn it on it might damage something else in the tv. the reason it is shutting off is because the power supply is putting out too much voltage. a repair cost will range around 300-400. this is a great model and well worth a repair. here is a web site that might help you in finding a repairman.
http://www.nesda.com/locator/state_search.php." <-- $300-$400 is too much! But throwing away a 300lbs TV will cost a lot of $$$ for the towing and dumping too. I haven't decide what to do yet.
Posted on Dec 19, 2007
Slinteriors
  • 8617 Answers
SOURCE: Sony KDP-65S550 red light keeps blinking
How many times is the LED blinking in between pauses? that is possibly a error code if you can determine the number of blinks.
Posted on Jun 28, 2008
ginko
  • 19396 Answers
SOURCE: standby light keeps blinking. tv wont turn on
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
Posted on May 07, 2009
Green light blinking, tv won't turn on
Lamp lifetime is not 100% predictable. A lamp may fail without notice, although this is not usually the case. The picture is more likely to become noticeably dimmer as the lamp nears the end of its lifetime.
While there is nothing wrong with using a lamp until it fails, some customers may want to purchase a new lamp and replace the existing one when they notice that it is aging.
If the lamp fails in a Mitsubishi MicroDisplay TV, there will be no picture on the screen and a red front panel LED indicator will illuminate.
Jan 17, 2008 | Mitsubishi WS-65813 65" Rear Projection...
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Hitachi UltraVision Tv Keeps turning off. The lamp LED blinks. Both light engine and lamp are new.
google.com/+GopakumarGopalan
Nov 13, 2013 | Hitachi 50V720 Television
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
