My cable box doesnt recognise my hd tv when i hook up the 2 with an hdmi cable
    Sergeant:
    Champion:
  • 319 Answers
Check operations manual for HDMI hook up. Some cab/box have to be switched from menu. If you can't use HDMI, use component cables instead, there's not much difference in picture quality. Possible bad HDMI cable
Posted on Apr 21, 2008
I have a Sony Bravia led digital kdl32m4000 tv, I am upgrading my satellite box to hd will I get the signal in hi def. or do I need to upgrade my tv?
No you don't need a new tv. Hook up your HD cable box using HDMI cable. Hdmi out on your cable box then hdmi in on your tv. You need your tv remote to change source input to hdmi.
Jun 10, 2017 | Sony Televison & Video
Can i hook up a seiki model SE39UY04 to a comcast HD box useing only the HDMI cable and which slot on the TV do I use
You should be able to. You should be able to hook the HDMI cable into the tv, than go to "TV Input" and select "HDMI 1" "HDMI 2" or "HDMI 3" depending on which input you used
Nov 30, 2014 | Seiki 39" Class 4K 120Hz LED Ultra HDTV -...
Lg 42" plasma
It may be that your cable box is outputting at a resolution your TV doesn't recognise or doesn't support. Do you have any other connection you can use from your cable box to your TV to check the settings?
Nov 18, 2017 | Televison & Video
I have the system hooked up and it comes on but not o the tv screen do i need the hd cable to make it work it is a flat screen tv please let me know what to do i have playstation 2 already hooked up and...
Are you using the AV connector cable? If so look on your tv for an av channel. Best thing to do though is Try using a HDMI cable. Most tv's recognise when a HDMI cable is plugged in and the tv switches automatically to the HD channel.
Hope this helps.
LJ.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
I am hooking up an HD box with hdmi on an Emerson LC320EM1F, the sound lags or has a buffer. What is my issue? I just purchased 2 of these TV's and they do the exact same thing. My other TV's that were...
It could be the version of hdmi cable you are using. It could also be what version hdmi the television is vs. what version hdmi cable you are using vs. what version hdmi the hd box is. See if you still get this problem when you use component.
Dec 02, 2010 | Televison & Video
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
