Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
The caution light is on with a shining bulb beneath it. Does this mean the bulb is bad?
  • 2,272 Answers
Yes correct.This is the indication to replace the bulb.Replacing the bulb will solve the problem. To get new bulb.please click on the link below http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hlp5085w-lamp-sm.htm ---------------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 17, 2010
When first turned on it was d but would get brighter now it has no picture after being on all night is it the lightbar reglator
Hey, it looks like u may have took it to far. Yes if lcd is like a shop light has inverter board which is a ballast and has bulbs in the screen assembly, so if dim to start and then gets brighter possible power supply or inverter board. Usually if bulbs go bad u can shine a flash light in the screen and see if u see any images which means the backlight is bad or bad screen. hope this helps
Apr 15, 2015 | RCA Televison & Video
Is there a way that incan by pass the lid light blinking
CAUTION CAUTION CAUTION CAUTION CAUTION CAUTIOON
normally this indicates lid not closed but possibly open circuit switch if washer is working cant be the switch to bypass the switch can be tecnical as you have a live feed to switch then switching wire fron switch te neon bulb then other bulb wire goes back to circuit so do away withe the switching wire from switch to bulb then live switch wire to other wire on buld that goes back to the circuit then switch has gone and the bulb no more flashing light
Aug 12, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My 2007 chevy tahoe cruise control light on the dash stop working. What might the problem be?
You may just have a bad bulb, you would need to remove the cluster and check the bulb, the bulb goes in at rear of the cluster, use a light to shine through hole to make sure you have the correct bulb, look at the front of the cluster while shining the light in the hole of the bulb you removed and you will see where you are, now if the cruise is not still working then you may have another problem ,if the cruise still works but theres no light then its just the bulb needs replacing, hope this helps,good luck.
Oct 13, 2010 | 2007 Chevrolet Tahoe
How to change the headlight
Open the hood and look on the back of the headlight fixture for a large plastic nut... This is the retaining ring that holds your headlight bulb in the fixture.
If by ' problem with my headlight shining' you mean your headlight no longer works , you can use the above to replace the bulb and that should solve the issue.
HOWEVER , if by ' problem with my headlight shining' you mean that the light is not aimed properly , you will need different instruction on how to solve the problem.
Jul 15, 2010 | 2004 Mazda 6
Yellow dash light, looks light light bulb with "!" inside of it
Somethign like this...
This symbol it means you have a light bulb out.
This symbol in orange stands for tire pressure monitor (TPMS sensor).
Hope this help (remember rated this).
May 07, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
Screen is black and can not see the images
hi,
he best way to see if its a bad power inverter board to the back light or if its the backlight "bulbs" is to shine a flashlight on the screen with the computer running.
If you can now see the text on the LCD then its a "back light" problem, the power inverter or the bulbs.
If you can not see any text its not the inverter or bulb. Try hooking your laptop to a external monitor. If the montior works that means your video card is good and that you more than likly have a failed LCD.
replacing the Inverter and entire LCD is normaly a pretty easy task.
  1. Bad inverter
  2. bad backlight
  3. bad connection
  4. all together bad LCD
None of those problems are expensive to repair.
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Toshiba Satellite A305-S6908 Laptop
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
Headlights shining high are the bulbs upside down
it's very difficult to install them upside down,but i guess anything is possible. wait until dusk,shine the lights on a flat surface and attempt to adjust until the lights look like they are shining in the center.
Apr 29, 2009 | 1998 Plymouth Voyager
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
198 people viewed this question
Jerry Greenberg
Jerry Greenberg
