Question about Hobart HL300-1STD 559 Watts Stand Mixer
The thread size for Hobart HL300 Mixer's thumb screw assy.
bigg t
  • 640 Answers
SOURCE: hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
Posted on Aug 24, 2008
SOURCE: Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant.  I think the difference is mostly in terms of the no volt interlock switch.  This means the KA style N50 bowl won't work with the CE models - too low.
Posted on Mar 17, 2009
  • 1262 Answers
SOURCE: need to know what type motor is in a hobart D 300 mixer
Look on the I.D. plate. Voltage should be listed. "PH" is for phase. It will either be single (1), or three (3) phase. "AMP" is for ampacity or the amount of power it consumes. Hobart's manual does not list the motor as an entire replacement unit. It only lists parts as if you were to rebuild the motor. Sorry.
Hope this helps some.
Posted on Apr 18, 2009
  • 109 Answers
SOURCE: Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
Posted on Aug 08, 2009
Cuisinexpert
  • 61 Answers
SOURCE: oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Posted on Aug 27, 2009
Miwer wont turn on. Was running then i shut it off now wont go back on
The precise model number and ML number would be helpful. It would tell if you have a safety cage and bowl height sense switch. There are huge differences between a D300, and an HL300. If you do have the cage, and nothing works, I would suspect you may have lost the magnet from the safety cage. Golden rule of trouble shooting is, "What has changed"
Mar 08, 2014 | Hobart 30 qt. Mixer
My wife has a K5A mixer from the '70's that she loves. While I was checking the brushes, I over-tightened the brush cap and broke the threaded part it screws into. Can I get a new part?
The Brush holder caps / covers for the K5 series whether Hobart or Kitchenaid by Whirlpool (after 1986 when Whirlpool bought Kitchenaid from Hobart) will fit the K5-A they just wont be flush like the older Hobart caps. They come in black or white.
Jan 10, 2012 | KitchenAid K5SS Heavy Duty Commercial...
Hobart Legacy mixer error code oc3 will not run.
Hobart mixer, HL300, stops and flashes as oc3, wounded what is broken?
Dec 08, 2010 | Hobart HL600 Legacy Stand Mixer
How do you add gear oil
The front screw in the top cover threads into a standoff. This standoff threads into the transmission top cover and acts as a fill plug.
Jul 11, 2010 | Hobart H600 Stand Mixer
How do you change or add oil to a Hobart H600 mixer
there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
Jan 02, 2010 | Hobart H600 Stand Mixer
The mixer rpm is too fast
No change available. The motor speed if fixed and the 3 speed transmission has fixed gear ratio's. Look at the new HL300 model. It has a stirr speed which is slower than first speed.
Does your mixer havea safety cage? If not, you will need to install one before too long , or the machine will not comply with current safety standards. Put the cost of the safety kit towards the HL300.
May 26, 2009 | Hobart D340-6007 Mixer
HOBART H600 Leaks oil.
There's an o-ring that goes around the attachment shaft,if you get a flashlight and look into the hole you will see a screw (left handed threads),remove screw and pull out shaft.Put the o-ring on and install the shaft and screw.
Feb 24, 2009 | Hobart H600 Stand Mixer
Jun 03, 2008 | Hobart N50 Stand Mixer
New (old) N50 ML-4749
You should be able to purchase the manual. I know that Hobart abandoned that policy a few years back -- unless they re-instated it. Call Mother Hobart and ask. 937-332-3000
There is a few tricks to these units, it would be tough to convey here. But here goes...
Remove back cover. Loosen 6 or 7 screws around outside of motor windings. Thump the nose of the mixer downward to break the seal. Watch for spacer washers where shafts go into motor case. Remove spring. Remove idler. Remove shifting guide. Remove gear assy. Leave beveled gears in place if possible. Clean. Use Darina II grease. (20 oz) Clean and permatex "seal". Tighten mounting bolts. Adjust set screw at back of planetary. (Double set screw. The first one is to lock the adjustment.) Test in 1st and then 3rd while turning the set screw. You just make it quiet for a proper adjustment.
Good luck -- Mike
Apr 28, 2008 | Hobart N50 Stand Mixer
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart HL300-1STD 559 Watts Stand Mixer Logo
106 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
